Hubsan X4 config
- goebish
- NRF Weirdo
01 Aug 2013 02:37 - 01 Aug 2013 02:39 #12676
by goebish
auto correct wreck
I guess thibaut is French, I'm too, everybody knows we're bad at english
Replied by goebish on topic Hubsan X4 config
sbstnp wrote: Naughty build LOL
auto correct wreck
Last edit: 01 Aug 2013 02:39 by goebish.
- sbstnp
01 Aug 2013 04:21 #12677
by sbstnp
Hihi, absolutely not true, my friend Philippe speaks a very good English
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Hubsan X4 config
auto correct wreck
Devo 10 + 4in1
- HeliBen
01 Aug 2013 18:05 #12701
by HeliBen
Replied by HeliBen on topic Hubsan X4 config
Does the latest nightly build support the additional channels for the X4 v2?
- goebish
- NRF Weirdo
01 Aug 2013 18:07 #12702
by goebish
No, send me a PM with your TX model and I'll send it to you.
- jason4207
09 Aug 2013 05:04 #12858
by jason4207
It does now.
If you have a 7E this model file is a good place to start:
Replied by jason4207 on topic Hubsan X4 config
HeliBen wrote: Does the latest nightly build support the additional channels for the X4 v2?
It does now.
- matrixFLYER
06 Sep 2013 15:06 #13604
by matrixFLYER
Replied by matrixFLYER on topic Hubsan X4 config
I just bought the module for my Devo10 A7105-500m.
Can the hubsan X4 V2 100% be enjoyed with deViation with no problems? Thanks!
I have the latest 3.0 official version.
- goebish
- NRF Weirdo
06 Sep 2013 15:09 #13605
by goebish
X4 V2 is 100% supported, but only in the nightly release.
- matrixFLYER
06 Sep 2013 15:12 - 06 Sep 2013 15:13 #13606
by matrixFLYER
Where can I get it? Thanks again.
Thanks. Is the installation of the nightly build like the installation of a standard new official relase?goebish wrote: X4 V2 is 100% supported, but only in the nightly release.
Last edit: 06 Sep 2013 15:13 by matrixFLYER.
- goebish
- NRF Weirdo
- matrixFLYER
06 Sep 2013 15:14 #13608
by matrixFLYER
is this the correct last updated ini file?
www.deviationtx.com/forum/model-configs/...art=0&start=20#12590
- goebish
- NRF Weirdo
06 Sep 2013 15:15 #13609
by goebish
Yes, but this is for Devo 10, you may have to adapt it to your TX.
- matrixFLYER
06 Sep 2013 15:19 #13610
by matrixFLYER
perfect, I have a wonderful devo 10
Are you an engineer that have you been able to hack the hubsan protocol? What's your background?
- goebish
- NRF Weirdo
06 Sep 2013 15:22 #13611
by goebish
I'm an electronics hobbyist only, that was the first time I used a logic analyzer (wonderful tool !!!), but I'm a programmer for a living.
- Daryoon
07 Sep 2013 17:04 - 07 Sep 2013 17:04 #13632
by Daryoon
Replied by Daryoon on topic Hubsan X4 config
goebish,
Could you take a photo of how it looks like when you have your analyzer hooked up? I just got the same one you have from [url=http://www.banggood.com/USB-Saleae-24M-8CH-24MHz-8Channel-Logic-Analyzer-Latest-Support-1_1_15-p-74101.html?p=5@1023051690201202T8]BangGood for a cheap $8.50[/url] and need some guidance to get started.
I believe it's still fresh on your mind.
Thanks in adavance.
-Daryoon
Thanks in adavance.
-Daryoon
Last edit: 07 Sep 2013 17:04 by Daryoon.
- goebish
- NRF Weirdo
- matrixFLYER
03 Oct 2013 23:03 #14224
by matrixFLYER
Hi, I just installed my A7105 module in my Devo 10 and with your config file everything works fine!! Thanks!!
If I turn on the transmitter then the hubsan it doesn't auto bind. If I go in the setup menu end push reinit it binds fine!
This happens to you?
I would like to have a description for your config file.
GEAR 1 lights OFF
RUD DR 1 for trotthle hold
fm0 low rate
fm1 high rate?
fm2?
There is the no flip function?
mix0/1/2 activated?
GEAR 1 lights OFF
fm0 low rate
fm1 high rate?
fm2?
mix0/1/2 activated?
- matrixFLYER
06 Oct 2013 11:58 - 06 Oct 2013 12:00 #14283
by matrixFLYER
By default the setting of the model is 4 channel but it uses gear channel to turn on off the light so i changed to 5 channel but in the official deviation documentation is written that only 4 channel are supported for hubsan protocol. I don't understand...i need someone to clarify this thing.
Furthermore I tried to lower the TX power output to 1uW (microW): look like that isnt' lowered like it is on my other dsm2 receiver. I can go very far and still have control. Does TX output in deViation works with the Hubsan protocol??
Ok I understood it by myself...the only thing that I do not understand is how is the autoflip prevented in FMOD1??? I don't understand if it's just the aileron/elevator throws or it's something else.matrixFLYER wrote: Hi, I just installed my A7105 module in my Devo 10 and with your config file everything works fine!! Thanks!!
GEAR 1 lights OFF
fm0 low rate
fm1 high rate?
fm2?
mix0/1/2 activated?
Last edit: 06 Oct 2013 12:00 by matrixFLYER.
- goebish
- NRF Weirdo
06 Oct 2013 15:43 #14285
by goebish
Hubsan X4 protocol now has 6 channels.
Channel 5 is for LEDs, Channel 6 to enable/disable flips.
- matrixFLYER
06 Oct 2013 15:46 #14286
by matrixFLYER
Thanks, perfect!
- goebish
- NRF Weirdo
31 Dec 2013 00:23 - 31 Dec 2013 00:25 #17537
by goebish
The latest nightly builds let you set the video transmitter frequency for the Hubsan X4 FPV (H107D)
It has better frequency range than the stock Hubsan FPV TX (5645-5945 MHz) and remembers last used frequency.
(Click the protocol name in Model setup screen to access protocol options)
Looks like it also works with Hubsan H102D (heli) and Hubsan Spyhawk (plane)
Last edit: 31 Dec 2013 00:25 by goebish.
Time to create page: 0.998 seconds
Model Configs
- Hubsan X4 config
