Hubsan X4 config
01 Dec 2015 22:55 #40539 by goebish
Replied by goebish on topic Hubsan X4 config
stringrazor wrote: Actually, you can do a mod. or so I've read. There's a pad on the cam board marked KEY. I've read that if you wire it to the LED + you can toggle the cam on/off with the LEDs from the Tx.
Nice tip !
01 Dec 2015 23:02 #40540 by stringrazor
Replied by stringrazor on topic Hubsan X4 config
I have tried it and it does work although it's not as reliable as I'd hoped. IIRC, two switch movements (on/off or off/on) are required to change the state of the camera and there's a timing issue so I found it would work/no work at times. I didn't really play with it much though, just tried it as a curiosity.
15 Dec 2015 20:22 #40963 by cyclops13
Replied by cyclops13 on topic Hubsan X4 config
stringrazor wrote: Using the X4 model I downloaded from the configs section, the LEDs can be toggled on/off with the lower throttle trim button. If the cam board is wired as I explained, the camera can be turned on/off remotely by toggling the LEDs.
Can you please point me to this ini file?
09 Feb 2016 15:57 - 09 Feb 2016 17:15 #42845 by Edrjune1
Replied by Edrjune1 on topic Hubsan X4 config
Okay guys, I know this model has been beaten to death since it's so popular, but I am struggling to get flips working on my H107l board. I bought the board separately for a Micro FPV build and the thing flies like a dream, but I can't get it to flip I downloaded goebish's .ini with !FMODE saying that it worked on turning flips on and off. However, it just doesn't seem to make a difference. The led switch works on gear fine, but not the flips on FMODE. Any suggestions or someone with a definitely working H107L that will flip?
Edit: Okay, it works. My bad. I guess I didn't know what a throw was. I'm very pleased.
Last edit: 09 Feb 2016 17:15 by Edrjune1. Reason: I'm Dumb
30 Dec 2016 23:50 #57381 by DonKracho
Replied by DonKracho on topic Hubsan X4 config
File Attachment:
File Name: model12.ini
File Size:4 KB
Just another config for Hubsan Quads. This was created on Devo 8 with 5.0.0 Firmware For me it works with Hubsan X4 V2, Hubsan FPV X4 (H107D), and Revell Nano Quad
Rudder DR down: Throtthe hold
Gear: Up LED on
FMOD 0: Ele/Ail: 70% DR - 40% Expo, Rudd: 60% DR - 25%, Expo, Flips disabled
FMOD 1: Ele/Ail: 100% DR - 25% Expo, Rudd: 100% DR - 0% Expo, Flips disabled
FMOD 2: Ele/Ail: 100% DR - 25% Expo, Rudd: 100% DR - 0% Expo, Flips enabled (same as FMOD1 except Flips)
Countdown timer triggered by Trottle and resetted by Rudder DR down to 3:30 min.
The hubsan4 image wasn't created by me, but I didnt find it for linking, therfore it is attached again.
01 Apr 2019 07:35 #73656 by bbq75ca
Replied by bbq75ca on topic Hubsan X4 config
hi everyone. i have a t8sg plus v2. will this model config file works on it?
Time to create page: 0.200 seconds
