- Settings Parkzone F27-Q Stryker Micro Ultra needed
- harald.doerr
10 Jan 2013 20:04 #4906
by harald.doerr
Settings Parkzone F27-Q Stryker Micro Ultra needed was created by harald.doerr
Somehow I can not manage to set this model. Anybody a settings file or a proxy?
Thanks a lot
Thanks a lot
- Sunwalker
11 Jan 2013 06:56 #4917
by Sunwalker
Replied by Sunwalker on topic Settings Parkzone F27-Q Stryker Micro Ultra needed
Morning
I have made a Delta DSM 2 File . I will order a Mini Stryker in the Next Time.
For this i have make this File but it´s only a Test File . For Ohter question´s contact me via Pn (gerne auch in Deutsch) or in The Rcline Forum
- harald.doerr
23 Jan 2013 11:02 #5430
by harald.doerr
Replied by harald.doerr on topic Settings Parkzone F27-Q Stryker Micro Ultra needed
Thanks for the file.
Was not really able to test it yet in full detail.
The Elevation seem to need a Reverse.
In addation some Dual Rate and Expo may be needed.
Other than that the file is great!
Thanks a lot.
Will upload my final versions, once its done and tested.
Thanks a lot.
- man
13 Feb 2013 13:47 #6356
by man
Replied by man on topic Settings Parkzone F27-Q Stryker Micro Ultra needed
Hello.
I also look for the .ini file for the UMX strycker F27-q, have you reussis to find the good solution for this model?
Thank you in advance.
Cordially.
Cordially.
- harald.doerr
15 Feb 2013 13:30 #6402
by harald.doerr
Was still not able to fly my Stryker yet
. But attached is the file which is working with the plane.
Have used 40% Expo on Elevator and Aileron.
Both are limited to 60%.
Shall be good enough for the first flights
No Expo or Dual Rate on the Rudder.
Regards, Harald
Regards, Harald
- man
24 Feb 2013 01:43 #6915
by man
Safety(Salute).
Thank you for the file, I am going to test, we shall see good, if the base(basis) is, ca will be deja well, I would refine the apres regulations.
Thank you.
Thank you.
- harald.doerr
24 Feb 2013 16:39 #6964
by harald.doerr
Have used the settings with the plane yesterday.
Frankly:
Its just great fun.
Be careful. Use D/R and Expo.
Plane is very much effected by wind.
Frankly:
- EduardS
11 Oct 2013 21:19 #14508
by EduardS
Harald, could you post the stryker.bmp in the Icon forum?
Replied by EduardS on topic Settings Parkzone F27-Q Stryker Micro Ultra needed
harald.doerr wrote: Hi,
Was still not able to fly my Stryker yet. But attached is the file which is working with the plane.
Regards, Harald
- harald.doerr
07 Dec 2013 08:14 #16354
by harald.doerr
Just saw your note. Will do that now.
- Sero
- RC-addicted
01 May 2014 18:59 #22838
by Sero
Replied by Sero on topic Settings Parkzone F27-Q Stryker Micro Ultra needed
Both posted configs have a nasty flaw, if the mix-switch is in any other position than 0, the elevons are not controlled at all..
Flick the switch by accident while flying, and bang, lawn dart...
If there is need for a corrected version, please make yourself heard here.
Time to create page: 0.047 seconds
Model Configs
