M120D01 with Bell head from WoW Please help
27 Jan 2013 04:31 #5554 by SamtheMan
Could someone make me a model file for a M120D01 with a Bell head. Wow hobbies sells it with both the Bell head and collective head. Use bell until comfortable than move over to full collective. No idea how I would set it up with the bell head. I am pretty sure it comes with the same receiver thats in the V120D02S V2 (Rx2636V-D).
Thanks.
29 Jan 2013 22:47 #5750 by SamtheMan
Replied by SamtheMan on topic M120D01 with Bell head from WoW Please help
No experts out there can help me out? Its the M120D01 with the V120D02S reciever, and it has the bell head. My concern is it has the pitch server, but a bell head. So how the heck would I program this?
30 Jan 2013 00:51 #5752 by Hexperience
Replied by Hexperience on topic M120D01 with Bell head from WoW Please help
Sorry, but I don't really know. I assume that if it has the normal v120d02s-v2 radio, that you program it as such and the fly bar just keeps it even more stable. It might even feel like a coax.
Just use a model file from a v120d02s-v2. It should work fine.
  • rbe2012
  • rbe2012's Avatar
30 Jan 2013 05:51 #5759 by rbe2012
Replied by rbe2012 on topic M120D01 with Bell head from WoW Please help
As far as I know is a Bell Head a special construction to add a mechanical flight stabilization by mixing the additional paddle forces to the blades. While the paddles are more stable, they make the flight more stable.
For controlling there is no difference concerning the servos.
What makes it different is the FBL-controller, which needs other swash plate settings (usually non instead of 120deg without FBL).
When the controller / rx is the same in both helis the programming should be mostly identically.
Theoretically spoken.
Time to create page: 0.096 seconds
