Trex 500 FlyBar with 2801
27 Jan 2013 23:32 #5594 by Rambosmurf
Trex 500 FlyBar with 2801 was created by Rambosmurf
Attached is my set up for my Trex 500 Flybar, Logictec 2100 Gyro. Swash is at 55,55,60, Travel Adjustments 100%, Expo/DR at 100/20 on 1 for both Ele/Ail. 100/Line on 2. Rudder is 60/30 because gyro is very fast. Gyro at 30/-50 for to modes (your will probably be different)
You have to set the trims for your heli and check all servo movement, plus the CCPM movement. Took me a while to figure it out but once I inverted the Ail in swash mix section it was all good.
Once again, don't forget to change title to model#.ini
09 Sep 2013 14:00 #13664 by Damo
Replied by Damo on topic Trex 500 FlyBar with 2801
Anyone: How easy is it to modify this model config to use an AR6100e 6Ch DSM2 Rx? I have a flybar 450.
Not sure where I need to change the channel assignments.
I understand trims, swash mixes will also need tweaking.
10 Sep 2013 05:40 - 10 Sep 2013 05:42 #13678 by billmester
Replied by billmester on topic Trex 500 FlyBar with 2801
here is my DSMX version T-rex 450 FB for DEVO 10. I fly it frequently, works so far.
Just set it to DSM2, bind and try ;-)
AR6115e (from left to right):
AUX1: pitch servo: front, upper.
GEAR: Gyro gain
RUDD: Gyro
ELEV: elevon servo: rear (outside on the left)
AILE: aileron servo: front, bottom.
THRO: ESC
Functions:
- 3 filght modes, curves by the T-rex manual FMOD
- "Sticky" throttle hold, RUDD D/R + Throttle lever to bottom first
- Hover pitch adjust, ELEV D/R + AUX4
- 3 gyro sensitivity, 2 fixed Head hold, higher and lower, 3rd is live pot variable for setup, both rate + HH mode, MIX, AUX5
- 1 stop watch + 1 countdown, throttle start and AILE D/R reset
Screen:
- 4 trims
- left: stopwatch + count down
- right, from top: cyclic, throttle, gyro gain
Last edit: 10 Sep 2013 05:42 by billmester.
12 Sep 2013 15:53 #13735 by Damo
Thank you, billmester.
Going to try this out tonight, :)
12 Sep 2013 17:27 - 12 Sep 2013 17:46 #13737 by Damo
All good, but no aileron control. The front servo's are respoding to elevator input, and collective, but no roll control.
I'm having a peek around now.
Ideas?
Edit: Must have lost a mixer changing to 6 channels ;) - stick input showing cyclic roll input, but channel monitor showing no corresponding output.
Last edit: 12 Sep 2013 17:46 by Damo.
12 Sep 2013 19:34 #13740 by billmester
yep - need to have 7... dunno why, but works only like this ;-)
13 Sep 2013 09:14 #13756 by Damo
I like the gyro gain on to aux pot.
I had my first crash today - thought it was a disaster seeing blades flying, but it was only the training gear going into orbit. Did break one plastic main blade grip, so pretty much no damage at all.
13 Sep 2013 20:31 #13767 by billmester
Sorry to hear that :(
I still remember the damp crrrach noise of the woodies breaking on my Honey Bee King 2 - that was my first heli + first crash... of many :whistle:
I hope it was not due to the .ini file :oops:
Not really Deviation related...and this is getting off topic... but as this is your 1st crash: do disassemble fully the complete head and check for bends otherwise you'll have baaad vibrations and more crashes...
14 Sep 2013 05:15 #13770 by Damo
Wasn't your .ini - I was using another. And it was my fault, I had just woken up after a day sleep (on night shifts), was too tired. But the little fella wanted to see the heli, what's a bloke to do? :)
I have a complete new head to put on, and no replacement parts for the plastic head, but I'll disassemble and check for straightness.
Time to create page: 0.177 seconds
