Devo8s rx802 and Gaui 500x Gu-ins
- protom
29 Jan 2013 16:32 #5727
by protom
Devo8s rx802 and Gaui 500x Gu-ins was created by protom
Hi everyone after reading a lot on the forum,
I finally decided to mod my devo8s with the WLToy's v911 transmitter and it works great
But as for my Gaui500X quadra I got the basic setup to work but I have no clue how to set up a switch to switch from manual flight mode to auto balance and GPS
As well as a return home switch
It was working under the normal devo8s firmware but with deviation I can't figure it out
Also after that is set I would love to find a way to move the camera gimbal would it be possible to have a switch that will enable me to control titl and roll control for the gimbal with the two little trims on the two top panels of the remote ?
And lastly does anyone know if I could get telemetry from my gaui500x I know I have it going to my osd but could I have it on the devo8s as well or do I need to get the walkera telemetry module ?
Anyone here could help I would be extremely grateful
Cheers
Cheers
- protom
30 Jan 2013 23:15 #5821
by protom
Replied by protom on topic Devo8s rx802 and Gaui 500x Gu-ins
anyone has any idea
31 Jan 2013 05:36 #5823
Replied by FDR on topic Devo8s rx802 and Gaui 500x Gu-ins
I don't know how to change it's modes, but if you have the original model file (the .bin one) and you could upload it zipped, or at least you could describe how it was set up, it might help...
You can use the upper trims for the bimbals: set up the trims to effect a two virtual channels (increase the step large enough), and use those virtual channels as sources for two unused real channels.
Yes, for the telemetry you need the telemetry module...
- protom
31 Jan 2013 06:18 #5824
by protom
Thanks for replying
Here is the connection schematics of the GUI so you get a better sense of how it is plugged
31 Jan 2013 09:39 #5830
So, here is my first try.
- throttle hold on RUD_DR;
- throttle channel has fail safe of -100 (i.e. it cuts the throttle, however if it has go home function, it might be better to use that instead...);
- ELE and AIL have DR with their appropriate switches;
- GEAR switches the go home on the GEAR channel (Ch5);
- FMOD switch should switch manual/auto/gps on the PITCH (AUX1) channel (Ch6);
- upper left trim moves the AUX2 channel (Ch7);
- upper right trim moves the AUX3 channel (Ch8).
If you have a RX801/802 the layout will be:
ELEV: red
AILE: white/red/black
THRO: orange
RUDD: yellow
GEAR: blue
AUX1: green
AUX2: black
AUX3: the other gimbal servo, if you have two of them...
ELEV: red
THRO: orange
RUDD: yellow
GEAR: blue
AUX1: green
AUX2: black
- protom
31 Jan 2013 12:29 #5837
by protom
Thanks a lot ill try it at once
- protom
31 Jan 2013 22:47 #5868
by protom
THank you so much everything seems to work fine I had to reverse the ELEV AILE and RUDD channels but all the rest works great
the only thing that doesnt work is the gymbal servo...
it doesnt seem to do anything when I move the trims
01 Feb 2013 14:18 - 01 Feb 2013 15:19 #5881
Sorry, my bad:
Change Ch7 and Ch8 mixer type from "Simple" to "Complex", and click on the "No Trim" button on them to show "Trim".
Last edit: 01 Feb 2013 15:19 by FDR.
- protom
01 Feb 2013 21:24 #5891
by protom
Thanks a lot everything seems to work fine
i ll post a video as soon as the wind is down and i can go out and fly
Time to create page: 0.227 seconds
Model Configs
- Devo8s rx802 and Gaui 500x Gu-ins
