VL Toys VL959
18 Feb 2013 12:44 #6518 by cmpang
VL Toys VL959 was created by cmpang
Thottle hold = RUD D/R
Dual Rate = FMOD
File Attachment:
File Name: VL_959.ini
File Size:4 KB
18 Feb 2013 13:31 #6521 by stevecox
Replied by stevecox on topic VL Toys VL959
Doesn't look like it, but did you have any luck with the lights or video/camera?
Adelaide
20 Feb 2013 02:18 #6602 by cmpang
Replied by cmpang on topic VL Toys VL959
nop... just basic controls. Will try to see if the lights/video switch is done by further channels or some other ways..
20 Feb 2013 06:02 - 20 Feb 2013 06:03 #6613 by cmpang
discover something very strange today.. found the range very short, the copter lost control at very short distance.. nothing helps but set the binding to fixed ID (1111). The situtation can be repeatable... no ID, short range, fixed ID (1111) everything ok
anyone get an explaination?
Last edit: 20 Feb 2013 06:03 by cmpang.
20 Feb 2013 07:26 #6618 by vlad_vy
Replied by vlad_vy on topic VL Toys VL959
What Deviation build do you use? Possible it fixed at experimental builds and will be fine at next stable release.
20 Feb 2013 08:20 #6620 by cmpang
vlad_vy wrote: What Deviation build do you use? Possible it fixed at experimental builds and will be fine at next stable release.
b9dae8a38714
but flying my VL911 is ok with auto-bind
20 Feb 2013 14:46 #6638 by stevecox
The V959 is a monster, its is definately only a 4 channel looking at the ppm signal, the other functions 4+ different ones, are done by using some sort of macro over the existing 4 channels. Its going to be fiddley to get it right - but the solution is going to have to be done in the tx programming itself similar to Hubsan. Looks like PB may get into it down the line, the quad is nice but with the stock tx its really wasted, its hard to fly it nice with the stock tx and take advantage of the features. Its a real shame WLToys and others dont pay attention to the forums and the major successors and WHY of the predecessor models (V911, V929) - its like they intentionally FCSK it up so you are forced to use the crummy tx. GRRR! I am at the point of creating a frankenTX with an old HKT6A to use the housing and those gimbals with some internals of the V959 tx, if I do I will post results here.
Adelaide
16 Mar 2013 19:21 #7833 by PhracturedBlue
Replied by PhracturedBlue on topic VL Toys VL959
I have just checked in a fix (available in the nightlies) that allows mapping:
channel 5 => lights
channel 6 => camera
channel 7 => video
Unless you play around with virtual channels, you need to applyeach to a swithc and then turn the switch on AND off to toggle the state (thatis, you toggle a switch on and the light turns on. then you turn the switch off an dthe light stays on, then you turn the switch on again and the light ges off, and then off again and the light stays off.
You need to press the 'Flysky' protocol button and enable 'WLToys V9x9' to make this work.
I've had my 959 for a while now, but this is the 1st I played with it much. I really like the video capability. I can see why folks are so keen on FPV now, as I'd love to have a live feed rather than just a recording
17 Mar 2013 17:30 #7864 by NT72
Replied by NT72 on topic VL Toys VL959
Hello PhracturedBlue,
I have this FW install: deviation-devo8-e05abdefdc9d
and this FS: deviation-fs-devo8-e05abdefdc9d.
I can´t press the Flysky button (it´s withe) and the next problem is,
that I can´t bind the V979.
what mistakes did I made? :(
Thanks for your help.
17 Mar 2013 17:40 #7867 by sbstnp
Replied by sbstnp on topic VL Toys VL959
NT72 wrote: Hello PhracturedBlue,
Did you read this?
deviationtx.com/forum/6-general-discussi...ou-need-to-read-this
Guess not.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
17 Mar 2013 17:51 - 17 Mar 2013 18:03 #7868 by NT72
holy cow
I did not.
I am a noob :unsure: maybe not, but I am always to be fast to check something out.
thanks for your hint.
Works perfect!!!! :cheer:
THANKS ALL FOR YOUR HELP!!!
Last edit: 17 Mar 2013 18:03 by NT72. Reason: it works...
17 Mar 2013 21:46 #7881 by stevecox
This is just magic, thanks a ton!
On mine I get, but all working 100%
Lights = CH5, Video = CH6, Camera = CH7
Adelaide
25 Apr 2013 16:02 - 25 Apr 2013 16:03 #9204 by DarkWolf
Replied by DarkWolf on topic WL Toys V959
I just got mine in today but am having trouble setting up the lights and camera. I understand you bind chan 5 and 6 to a switch and turn it on/off to trigger, but I'm still having issues.. Can't seem to get the lights to trigger.
Last edit: 25 Apr 2013 16:03 by DarkWolf.
25 Apr 2013 17:40 #9207 by DarkWolf
Whoops.. Never mind.. I forgot about having to:
"You need to press the 'Flysky' protocol button and enable 'WLToys V9x9' to make this work."
My bad. :)
28 Apr 2013 09:01 - 28 Apr 2013 09:02 #9300 by vlad_vy
PB, can you find how implemented 'roll' function in V959? If press the Roll button, V959 can do flip. If press the Roll button once again, V959 do not flip.
Right now V959 can't do flip with any channels travel, up to 250% (Deviation).
Last edit: 28 Apr 2013 09:02 by vlad_vy.
07 Jul 2014 06:52 - 07 Jul 2014 06:54 #24450 by jlk69
Replied by jlk69 on topic VL Toys VL959
I am trying to toggle the lights and set up a roll switch. Can some one that has got this working post there ini file for this model. Not sure how to set up in the mixer section. I did change the setting in the Flysky box to 9x9 on.
Last edit: 07 Jul 2014 06:54 by jlk69.
18 Jul 2014 06:58 #24667 by jlk69
I just wanted to bump this thread. Can any body post there ini model file with working light switch or camera or roll?
21 Jul 2014 16:48 #24731 by NT72
here is my ini file with lights and modules working for devo8.
22 Jul 2014 04:20 #24749 by jlk69
Thanks will try it out.
23 Jul 2014 21:49 - 23 Jul 2014 21:50 #24763 by jlk69
Good news!! Got lights to work. Thanks NT72. Has anybody got the auto flip function to work? BTW my v959 board is a replacement for the v929 board that blew a motor fet. I bought lights and canopy from v959. Don't have any modules from v959 so can't test these.
Last edit: 23 Jul 2014 21:50 by jlk69.
Time to create page: 0.164 seconds
