Ladybird V1 (Led on Aux ?)
- ursus69
01 Dec 2014 20:31 #26715
by ursus69
Hi Franck,
You say the ladybird firmware??
In a old reply, you said that you solved with a PNP transistor?
Salut Franck,
Vous dites que le ladybird firmware??
Dans une réponse vieux, vous avez dit que vous avez résolu avec un transistor PNP?
Merci
Replied by ursus69 on topic Ladybird V1 (Led on Aux ?)
Franck wrote:
ursus69 wrote: I've tried with tho others channels...but no work...
Any idea to work in the aux connector?
Thank you!!
As tu mis a jour le firmware ? par defaut fonctionne pas.
Have you updated the firmware? Default not.
Hi Franck,
Salut Franck,
Merci
- Franck
03 Dec 2014 15:28 - 03 Dec 2014 15:31 #26743
by Franck
Replied by Franck on topic Ladybird V1 (Led on Aux ?)
Last edit: 03 Dec 2014 15:31 by Franck.
- ursus69
03 Dec 2014 16:33 - 08 Dec 2014 21:32 #26744
by ursus69
Hi Franck!
I made a similar module, but only with resistors...and only works 2 smd led...
Salut Franck !
Je ai fait le même module , mais seulement avec des résistances ... et ne fonctionne que deux SMD LED ...
Franck wrote: Oui j'ai mis a jour le firmware et ensuite j'ai utilisé un transistor pour que cela fonctionne
Yes I updated the firmware and then I used a transistor for it to work
Hi Franck!
Salut Franck !
Last edit: 08 Dec 2014 21:32 by ursus69.
- ursus69
17 Dec 2014 02:08 #27056
by ursus69
Hi Franck!
Can you send me the diagram of the module? And the list of components?
Thank you very much
Pouvez-vous me envoyer le schéma du module ? Et la liste des composants ?
Merci beaucoup
Thank you very much
Merci beaucoup
- ursus69
24 Dec 2014 12:49 #27197
by ursus69
Hi Franck!
Can you take more pictures or send me the diagram & components?
Thanks!!
Thanks!!
- Franck
27 Dec 2014 20:39 - 27 Dec 2014 20:42 #27273
by Franck
Last edit: 27 Dec 2014 20:42 by Franck.
- ursus69
27 Dec 2014 22:17 #27274
by ursus69
Hi Franck!
Thank you!!
But what components are? In the picture are several types of components...
You can give me more details, please?
Thanks again!
Salut Franck !
Merci !!
Mais quels composants sont ? Dans l'image existe plusieurs types de composants ...
Vous pouvez me donner plus de détails , se il vous plaît ?
Merci encore!
Franck wrote: La commande est simple, un transistor NPN, la gache est activée par le connecteur vert.
Il faut commander le transistor avec GEAR
Hi Franck!
Thank you!!
Thanks again!
Salut Franck !
Merci !!
Merci encore!
- ursus69
09 Apr 2015 19:54 #30953
by ursus69
Franck,
Can you give me the number and specs of the resistors and others components?
Thanks!!
Thanks!!
- Franck
27 Apr 2015 19:32 #31718
by Franck
Here is a picture with the components. I can not take the values with the multimeter, because of the varnish. But you can rely on numbers. cordially
nsm08.casimages.com/img/2015/04/27/15042...4415420713212636.jpg
- ursus69
28 Apr 2015 18:17 #31745
by ursus69
Hi Franck!
Thanks for the picture! I'm very bad with electronic
What is the brown component??
The list will be:
- 470 resistor
- 390 resistor
- 15R0 ¿resistor?
- ¿2G? ¿transistor? ¿NPN?¿PNP?
- ¿Brown component?
Thanks for all!
And sorry for the inconvenience
The list will be:
- 470 resistor
- 390 resistor
- 15R0 ¿resistor?
- ¿Brown component?
Thanks for all!
- Franck
16 May 2015 20:27 #32659
by Franck
15RO - 15 ohms
470 - 470 ohms
390 - 390 ohms
2G - Transistor PNP
470 - 470 ohms
390 - 390 ohms
2G - Transistor PNP
Time to create page: 0.225 seconds
Model Configs
- Ladybird V1 (Led on Aux ?)
