Blade mCX2 Model and Icon [Devo7e]
13 Aug 2013 03:37 - 13 Aug 2013 09:11 #12938 by Daryoon
Blade mCX2 Model and Icon [Devo7e] was created by Daryoon
Just finished creating an icon for the mCX2. Give it a test.
The FMOD switch will flip between beginners and advance mode. Just like the button on the mCX2 remote.
Adjust expo to your taste.
I made it a little on the "hot" side. :)
Throttle hold (TH) at the 1 position will prevent the motor from spinning. Getting used to this will help you learn good habits for when you're flying CP helis.
Mapped Buttons:
Up+ is a shortcut to go into the Model setup for binding, loading and those type of operations.
DN- is a shortcut to go directly to the Model Mixer.
L- resets the flight timers
Timer1: Countdown from 5:30
Timer2: Count up
Timer3: Permanent timer. Like a trip odometer. Won't reset until you go into the timer menu and reset it.
Hidden Timer4: Inactivity timer. If you do not touch your radio sticks for 10mins, the alert will sound to let you know you left your radio on.
https://app.box.com/s/47iwuqzf2p55hjw3mk9q
Last edit: 13 Aug 2013 09:11 by Daryoon.
16 Aug 2013 22:37 #13008 by chrisleon32
Replied by chrisleon32 on topic Blade mCX2 Model and Icon [Devo7e]
do you know how i could use this with devo10? or point me in the right direction? thanks! good work here!
  • rbe2012
  • rbe2012's Avatar
17 Aug 2013 09:27 #13014 by rbe2012
Replied by rbe2012 on topic Blade mCX2 Model and Icon [Devo7e]
You can use it - the Devo10 has the same buttons as the 7e, even more. Everything for Devo7e will work, but make no use of the additional buttons (what could make it more comfortable...).
18 Aug 2013 14:57 #13029 by chrisleon32
thank you!
Time to create page: 0.164 seconds
