Blade mCX2 Model and Icon [Devo7e]
- Daryoon
13 Aug 2013 03:37 - 13 Aug 2013 09:11 #12938
by Daryoon
Blade mCX2 Model and Icon [Devo7e] was created by Daryoon
Just finished creating an icon for the mCX2. Give it a test.
The FMOD switch will flip between beginners and advance mode. Just like the button on the mCX2 remote.
Adjust expo to your taste.
I made it a little on the "hot" side.
Throttle hold (TH) at the 1 position will prevent the motor from spinning. Getting used to this will help you learn good habits for when you're flying CP helis.
Mapped Buttons:
Up+ is a shortcut to go into the Model setup for binding, loading and those type of operations.
DN- is a shortcut to go directly to the Model Mixer.
L- resets the flight timers
Timer1: Countdown from 5:30
Timer2: Count up
Timer3: Permanent timer. Like a trip odometer. Won't reset until you go into the timer menu and reset it.
Hidden Timer4: Inactivity timer. If you do not touch your radio sticks for 10mins, the alert will sound to let you know you left your radio on.
https://app.box.com/s/47iwuqzf2p55hjw3mk9q
Mapped Buttons:
Timer2: Count up
Last edit: 13 Aug 2013 09:11 by Daryoon.
- chrisleon32
16 Aug 2013 22:37 #13008
by chrisleon32
Replied by chrisleon32 on topic Blade mCX2 Model and Icon [Devo7e]
do you know how i could use this with devo10? or point me in the right direction? thanks! good work here!
17 Aug 2013 09:27 #13014
Replied by rbe2012 on topic Blade mCX2 Model and Icon [Devo7e]
You can use it - the Devo10 has the same buttons as the 7e, even more. Everything for Devo7e will work, but make no use of the additional buttons (what could make it more comfortable...).
- chrisleon32
18 Aug 2013 14:57 #13029
by chrisleon32
thank you!
Time to create page: 0.184 seconds
Model Configs
- Blade mCX2 Model and Icon [Devo7e]
