MCPX BL ?
08 Sep 2013 10:27 #13647 by bastien
MCPX BL ? was created by bastien
Anybody can it put the file of the on-line mcpx bl?
Thank you
  • rbe2012
  • rbe2012's Avatar
11 Sep 2013 05:11 #13698 by rbe2012
Replied by rbe2012 on topic MCPX BL ?
Here is mine; configured for the old gui (aka deviation 3.0.0):
File Attachment:
File Name: model25.ini
File Size:2 KB
It has some expo and uses the flight mode switch (FMode1+2 for acro).
11 Sep 2013 13:34 #13708 by Tom Z
Replied by Tom Z on topic MCPX BL ?
I have models posted here:
Blade mCPX - Standard Settings
deviationtx.com/forum/model-configs/1706...px-standard-settings
Blade mCPX - Beginner Settings
deviationtx.com/forum/model-configs/1700...px-beginner-settings
These are for the brush or brushless mCPX.
I had the brushless and test flew the models on them.
12 Sep 2013 20:36 #13742 by bastien
Replied by bastien on topic MCPX BL ?
the adjustment of the gyro is possible and on which channel ?
Thank
13 Sep 2013 00:23 - 13 Sep 2013 00:24 #13750 by Tom Z
The gyro gain on the mCPX can not be adjusted. It is preset in the Flybarless 3n1 Control Unit,RX/ESCs/Gyros. This is why I do not have gyro gain listed in the models I posted.
Last edit: 13 Sep 2013 00:24 by Tom Z.
13 Sep 2013 00:28 #13751 by Drexz
Replied by Drexz on topic MCPX BL ?
Thats not what I have read.
Have not tested it myself as stock gain was good on my mCPX BL.
This is done by adjusting the value of channel 5
0% = stock gain.
Increasing the number will increase the gyro gain. Range: 0% to 100%
Decreasing the number decreases the gain. Range: -100% to 0%
Think its only heading hold as well.
Give it a test and report back :)
01 Oct 2013 01:17 - 11 Oct 2013 17:26 #14184 by jazzjohn
Replied by jazzjohn on topic MCPX BL for Devo 6
Here's a model for the Devo 6, derived from Tom Z's model for the Devo 8.
Throttle hold is on the Fmod switch and the flight modes are on the mix switch.
The normal mode matches the idle-up mode in the top half of the curve so you can switch from one mode to the other while hovering upright with no jumps in flight.
Last edit: 11 Oct 2013 17:26 by jazzjohn. Reason: Corrected error in attached file
08 May 2014 20:54 #23033 by Tom Z
Drexz wrote: Thats not what I have read.
0% = stock gain.
This was just posted.
deviationtx.com/forum/model-configs/2687...bl-3d-settings#23028
Time to create page: 1.488 seconds
