LadyBird V2 Devo 7E config request please
06 Oct 2013 15:02 #14284 by MassiveOverkill
LadyBird V2 Devo 7E config request please was created by MassiveOverkill
Deviation 3.0. Thanks.
06 Oct 2013 17:54 - 06 Oct 2013 17:56 #14287 by FDR
It's quite easy:
- DEVO protocol with 7 channels;
- simple 4 channels (EATR) with some expo if you like;
- two fixed values (-100, +100) on ch7 to switch between stability and agility modes, which you can easily achieve with a switch as the source and the min/max function;
- perhaps a -100% failsafe value on the throttle channel (Ch3)...
Last edit: 06 Oct 2013 17:56 by FDR.
06 Oct 2013 18:36 #14288 by MassiveOverkill
Replied by MassiveOverkill on topic LadyBird V2 Devo 7E config request please
So for someone who isn't comfortable setting it up manually yet but really comfortable just copying a config file, mostly because of time constraints do you think you could upload a config? Thanks.
06 Oct 2013 19:03 #14289 by FDR
Here it is.
I don't have a DEVO 7E, so I didn't try it...
06 Oct 2013 22:40 - 06 Oct 2013 22:40 #14290 by MassiveOverkill
Works great, many thanks FDR!
Last edit: 06 Oct 2013 22:40 by MassiveOverkill.
07 Oct 2013 04:11 #14291 by FDR
I'm glad I could help.
Eventually you can fine tune the expos I set to your needs, or configure DR dependent on FMOD for example...
13 Jan 2014 15:37 #18479 by Littlepip
Replied by Littlepip on topic LadyBird V2 Devo 7E config request please
Stupid Question how do you use these setup's. I have only had the 7e one day and I am not sure what to do with your setup as I also have a Ladybird v2 and would like to try your settings
Gary ( Very New )
Time to create page: 0.712 seconds
