HOLD Super CP
- Neposeda_ua
10 Oct 2013 08:03 #14417
by Neposeda_ua
HOLD Super CP was created by Neposeda_ua
How to setup HOLD to stop the motor and servo shifted to neutral (middle) position.
I can not make out with a HOLD on the new menu firmware ((
- RoGuE_StreaK
10 Oct 2013 09:38 #14423
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic HOLD Super CP
Go into each Channel and set the Safety. Set the button it responds to and what value it should go to when engaged.
- svoy
10 Oct 2013 16:39 #14464
by svoy
Replied by svoy on topic HOLD Super CP
Excruciates by such question firmware version Deviation 3.0.0. Where that have read that in it have the opportunity set the counter total flying model. Can someone tell me how to do this?
10 Oct 2013 16:45 #14467
Replied by rbe2012 on topic HOLD Super CP
On timer page define a timer as a "permanent timer" and associate a switch to it. The values are stored and the timer will start at the last position when you reload the model.
Time to create page: 0.064 seconds
Model Configs
- HOLD Super CP
