J-Bug, HK Mini Swift
10 Oct 2013 09:21 - 10 Oct 2013 09:22 #14421 by matrixFLYER
J-Bug, HK Mini Swift was created by matrixFLYER
model 4 is jbug model5 is mini swift. All with DSM2 receivers.
In the jbug setting with GEAR1 you can activate a mix between throttle and elevator. When you rise throttle the elevator push the plane down.
_______________________________________
The mini swift is with FMOD0/1/2 with increased throws.
GEAR1for turning on the lights (I installed some led in my HK mini swift connected to GEAR channel) and mix0/1/2 for enabling/disabling gyro stabilization with Lemon RX dsm2 receiver with integrated gyro. (1 and 2 are gyro on, you can change MIX2 to activate AVCS)
In all model there is a permanent timer and a single flight timer activated with throttle channel so if you don't use a spektrum receiver you have to change the throttle channel source according to you receiver channel order.
In all the model there is throttle cut WITH RUD0.
I also made some icons here:
www.deviationtx.com/forum/bw-icons-for-d...enix-simulator#14420
Last edit: 10 Oct 2013 09:22 by matrixFLYER.
Time to create page: 0.130 seconds
