Settings for Wing Wing Z-84 needed
07 Dec 2013 08:26 #16358 by harald.doerr
Settings for Wing Wing Z-84 needed was created by harald.doerr
I am using above mentioned plan and have some issue to set it up. :sick:
My idea is to use MIX to adjust the Elevator from 50% to 75% and 100%.
Any body Wing Wing settings?
Example settings are highly appreciated. B)
07 Dec 2013 09:38 #16363 by kreidler
Replied by kreidler on topic Settings for Wing Wing Z-84 needed
Do you want to implement some kind of Dual-Rate only for the elevator?
This could be achieved in many ways depending on your personal needs. Somebody wants to have Dual-Rate on the D/R switches for every function. I prefer using the FMOD switch to have all on one switch. Of course, you could use also the MIX switch but if you only want to limit the elevator I would use the ELEV D/R switch. If you need the three settings of 50,75 and 100 you should to use one of the three position switches to keep it easy (other ways are possible :) ). In my opinion the MIX should be for different mixing adjustments as long as possible. But these are just my two cents. If you are unsure please post your elevon origin and I could add the switch you want to have.
07 Dec 2013 13:03 #16366 by harald.doerr
Replied by harald.doerr on topic Settings for Wing Wing Z-84 needed
This is the file I am currently using.
Looking for Dual Rate for Elevator
50% / 75% / 100%
Switch Elev D/R is fine to be used
File Attachment:
File Name: model21.ini
File Size:4 KB
Thanks a lot in advance,
Harald
07 Dec 2013 16:29 #16374 by kreidler
Just Tor avoid misunderstandings: All Dual-Rate switches are two Position switches only. If you need all three values to be set only MIX or FMOD could be used.
07 Dec 2013 16:46 #16376 by harald.doerr
Sorry. My mistake.
MIX is my preference.
08 Dec 2013 10:03 #16401 by kreidler
I just did some changes to your ini:
MIX0=100% - MIX1=70% - MIX2=50% like on DR switches with 0 and 1.
Addtionally I enabled the trims for all positions. Otherwise either AIL or ELE trims would not be available in the reduced settings.
Please bear in mind that you have to change the Expo settings for every of the three settings. That means on 6 mixer pages for every output!
I do normally prefer to deactivate for the mixed function. E.g. Page1: AIL gets the Expo, page2 !ELE do not get any Expo. This could result in some kind of snap flaps :P .
But this is up to you.
17 Dec 2013 20:52 #16759 by harald.doerr
Thanks for the file and the support.
Did not yet have an opportunity to test the settings. Unfortunately my Wing Wing needs some adjustments first.
Will provide feedback after having tested the settings.
Thanks again.
Time to create page: 0.106 seconds
