Need settings for SH 6047 (Scorpion)
- southtirol32
08 Jan 2014 17:16 #18228
by southtirol32
Need settings for SH 6047 (Scorpion) was created by southtirol32
i search a model.ini file for the SH 6047, i have the devo 7e transmitter with nrf module mod, i can bind whit the devo?
THX
THX
- cx12
20 Feb 2014 17:15 #20654
by cx12
Replied by cx12 on topic Need settings for SH 6047 (Scorpion)
This clone of the Walkera scorpion is not using the walkera "Devo" protocol so it will not work with deviationx at this time.
- btoschi
17 Mar 2014 20:46 - 17 Mar 2014 20:46 #21629
by btoschi
Replied by btoschi on topic Need settings for SH 6047 (Scorpion)
Try YD-717 protocol (which needs nRF24L01), it should work.
I cannot provide an .ini yet as my Devo is still not modded (waiting for universal module PCB to arrive).
Last edit: 17 Mar 2014 20:46 by btoschi.
- southtirol32
21 Mar 2014 20:46 #21711
by southtirol32
Replied by southtirol32 on topic Need settings for SH 6047 (Scorpion)
very nice when i can use the devo7e with the 2 way switch .....
i wait and i can test the .ini file with my scorpio
- marcoose
10 May 2014 17:35 #23116
by marcoose
Replied by marcoose on topic Need settings for SH 6047 (Scorpion)
Has anyone set one of these up?
I just tried mine out with a new blank model and YD717 protocol.
It binds fine, and the throttle seems to work, but I can't figure out what the other channels should be. I moved the ail/ele stick and rudder to all sorts of positions, but no matter what when I try to lift off it pitches backwards full tilt. I would have expected that maybe the channels were reversed or assigned to the wrong stick, but I can't match up the right ones since it seems to fly backwards no matter what stick I move.
Thanks for any tips!
- AirPatoine
15 May 2014 23:29 #23268
by AirPatoine
Replied by AirPatoine on topic Need settings for SH 6047 (Scorpion)
Have you had any luck? I just revived my Scorpion - had a bad motor. I also updated to the new Deviation firmware and found I can bind, but no luck with flying it with my Devo 10. Looks like channel 5 controls the rear motors. I thought any tricopter settings could be modified to make it work, but haven't found one yet.
- marcoose
16 May 2014 00:29 - 16 May 2014 02:05 #23269
by marcoose
EDIT - working now!
Had some trouble with 4.0.1 release, but using the nightly build it works great! I am using the Skywalker YD717 option
Refer to model file two posts down -- thanks hexfet!
Last edit: 16 May 2014 02:05 by marcoose.
16 May 2014 01:25 #23270
Replied by hexfet on topic Need settings for SH 6047 (Scorpion)
Nice! Just watched a video and looks like a fun 'copter.
The video showed an auto-flip capability. You might try that on channel 5. Below is what I use for the YD717. The YD requires the scale to be over 90 before the auto-flip will activate. With the gear switch in postion 1 and scale > 90, moving the cyclic fully in any direction initiates a flip in that direction.
[channel5]
template=simple
[mixer]
src=GEAR1
dest=Ch5
[channel5]
template=simple
[mixer]
src=GEAR1
dest=Ch5
- marcoose
16 May 2014 02:01 - 16 May 2014 02:04 #23271
by marcoose
Thanks so much for your help and work on this! Works perfectly! Here is my model file using the latest nightly build.
I am using a Devo 10 with FMOD 0/1/2 = 40%/70%/100%, and the AILE D/R is my flip enable (same on all my quads).
I also use a custom 'toggle3.bmp' that has a spinner/flat arrow to indicate flip status, and a light bulb for V222 lights on/off
Last edit: 16 May 2014 02:04 by marcoose. Reason: describe settings
- Temporal Flux
06 Apr 2016 22:23 - 07 Apr 2016 01:47 #45971
by Temporal Flux
Replied by Temporal Flux on topic Need settings for SH 6047 (Scorpion)
Hi guys, I finally registered after hanging around for a couple of months.
I got the Scorpion today (and got to work putting some LEDs on it).
Anyway, thanks to marcoose for the model file. I have a Devo 7E with 3x2 switch mod so, I took the liberty of modifying marcoose's file (I hope I got it right - works so far). For those interested, here it is:
The rates are on SW B0/B1/B2, Flip mode is on FMODE1, and throttle hold on HOLD1.
I have 14 quads/hexs now, almost all of them deviated. A big thankyou to everyone for their hard work.
Last edit: 07 Apr 2016 01:47 by Temporal Flux.
Time to create page: 0.125 seconds
Model Configs
- Need settings for SH 6047 (Scorpion)
