Multiplex Funcopter
- Hot_Wheels
24 Jan 2014 20:06 #19041
by Hot_Wheels
Multiplex Funcopter was created by Hot_Wheels
Does anyone have a set up for a FC using a 401b and a DSM rx? I started to work one but im not sure how to set up swash due to there is no mixing? do i have to set the model up in a plane menu?
- Tom Z
24 Jan 2014 22:24 - 26 Jan 2014 14:20 #19051
by Tom Z
Replied by Tom Z on topic Multiplex Funcopter
It should be set up as a Heli and use 1SERVO90°.
Here is a model I made. Let me know if it works OK and I will make Beginner and Standard settings models for people and list it in my master list sticky.
I don't have a Funcopter to test fly it. I made this off a setup on a web site for the Funcopter with the DX6I.
Power it up but don't take off and make sure the servos are working in the correct directions. I have ELEV and RUDD reversed and the rest normal as instructed.
If the servos are working in the correct directions lift off just a little bit and see if the tail is holding and the gyro is working in the correct direction. I don't know what the DIR on the GY401 direction should be set to. Either NOR or REV.
This model is for deviation firmware v4 and the DEVO 6/6S/7e/8/8S/10/12/12S.
Rename the model to a model number you have free.
- Gyro gain is on the Gear Switch. Adjust as needed. 0: 70.0%
- Throttle hold on the RUDD D/R switch
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- Telemetry=Off
- No Fixed ID
- Stick Mode 2
- If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
1: 30.0%
DR/EXPO - Standard Settings
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
Last edit: 26 Jan 2014 14:20 by Tom Z.
- Hot_Wheels
26 Jan 2014 17:43 #19184
by Hot_Wheels
Replied by Hot_Wheels on topic Multiplex Funcopter
thanks!! I will try it later tonight!
- Tom Z
26 Jan 2014 18:05 - 28 Jan 2014 02:25 #19186
by Tom Z
Your welcome.
Do you have a DSM2 or DSMX receiver?
I made the model for DSMX. If you have a DSM2 receiver you might have to change Protocol=DSMX to Protocol=DSM2
Edit: Here is a model for DSM2 if you need it.
Last edit: 28 Jan 2014 02:25 by Tom Z.
- mindo
04 Apr 2016 21:42 #45798
by mindo
Replied by mindo on topic Multiplex Funcopter
Here my very simple Funcopter Model.ini using DEVO protocol.
Throttle, Ail, Elev and Rudd with Expo Dual Rate assigned to respective switch. Position 0=linear, position 1=Expo
Gear switch used as throttle hold on -110% to turning immediately off motor
Two timers started by throttle and resetted with AUX4 e AUX5 Knob
Hoping could be useful!
_________________
name=FunCopter
mixermode=Advanced
type=plane
[radio]
protocol=DEVO
num_channels=4
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
max=97
min=-75
subtrim=70
template=expo_dr
[mixer]
src=ELE
dest=Ch1
[mixer]
src=ELE
dest=Ch1
switch=ELE DR1
curvetype=expo
points=30,30
[channel2]
reverse=1
subtrim=200
template=expo_dr
[mixer]
src=AIL
dest=Ch2
[mixer]
src=AIL
dest=Ch2
switch=AIL DR1
curvetype=expo
points=30,30
[channel3]
safetysw=GEAR1
failsafe=-100
safetyval=-100
template=simple
[mixer]
src=THR
dest=Ch3
curvetype=expo
points=35,35
[channel4]
reverse=1
template=expo_dr
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
switch=RUD DR1
curvetype=expo
points=30,30
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=2
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
step=2
value=21,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
step=2
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=2
value=-61,0,0
[timer1]
type=countdown
src=THR
resetsrc=AUX4
time=480
[timer2]
src=THR
resetsrc=AUX5
[timer3]
type=countdown
src=THR
resetsrc=AUX5
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,2
V-trim=65,10,3
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,39,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,RUD DR
Toggle=13,10,0,5,0,ELE DR
Toggle=22,10,0,4,0,AIL DR
Toggle=31,10,0,214,0,GEAR
Toggle=40,10,0,0,0,None
TxPower=102,7
V-trim=55,10,0
H-trim=1,59,0
V-trim=69,10,0
H-trim=78,59,0
Big-box=2,12,None
Small-box=2,28,None
Small-box=2,38,None
Small-box=2,48,None
Bargraph=79,30,FMODE2
Bargraph=85,30,FMODE2
Bargraph=91,30,FMODE2
Bargraph=97,30,FMODE2
quickpage1=Telemetry monitor
quickpage2=None
quickpage3=None
quickpage4=None
_________________
name=FunCopter
mixermode=Advanced
type=plane
[radio]
protocol=DEVO
num_channels=4
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
max=97
min=-75
subtrim=70
template=expo_dr
[mixer]
src=ELE
dest=Ch1
[mixer]
src=ELE
dest=Ch1
switch=ELE DR1
curvetype=expo
points=30,30
[channel2]
reverse=1
subtrim=200
template=expo_dr
[mixer]
src=AIL
dest=Ch2
[mixer]
src=AIL
dest=Ch2
switch=AIL DR1
curvetype=expo
points=30,30
[channel3]
safetysw=GEAR1
failsafe=-100
safetyval=-100
template=simple
[mixer]
src=THR
dest=Ch3
curvetype=expo
points=35,35
[channel4]
reverse=1
template=expo_dr
[mixer]
src=RUD
dest=Ch4
[mixer]
src=RUD
dest=Ch4
switch=RUD DR1
curvetype=expo
points=30,30
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
step=2
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
step=2
value=21,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
step=2
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
step=2
value=-61,0,0
[timer1]
type=countdown
src=THR
resetsrc=AUX4
time=480
[timer2]
src=THR
resetsrc=AUX5
[timer3]
type=countdown
src=THR
resetsrc=AUX5
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,2
V-trim=65,10,3
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
TxPower=102,7
V-trim=55,10,0
H-trim=1,59,0
V-trim=69,10,0
H-trim=78,59,0
Big-box=2,12,None
Small-box=2,28,None
Small-box=2,38,None
Small-box=2,48,None
quickpage2=None
quickpage3=None
quickpage4=None
Time to create page: 0.211 seconds
Model Configs
- Multiplex Funcopter
