Bixler 2 with Flaps + Devo 8s + RX802
- Garnett-Bennett
08 Feb 2014 16:50 - 09 Feb 2014 00:05 #19997
by Garnett-Bennett
Bixler 2 with Flaps + Devo 8s + RX802 was created by Garnett-Bennett
H-King Bixler 2 with Flaps configured with 50% and 100% on MIX1/MIX2.
Devo8s + RX802
Flaps servos connected to GEAR and AUX1
Devo8s + RX802
Last edit: 09 Feb 2014 00:05 by Garnett-Bennett.
- Jasen
13 Feb 2014 18:24 #20237
by Jasen
Replied by Jasen on topic Bixler 2 with Flaps + Devo 8s + RX802
Thanks for sharing your file. May ask what version of Deviation you are running? Did you use a Y cable and hook both aileron servos to the ale port on the RX? I am primarily a Helicopter pilot. I have has a couple flights using using a 3 channel plane. I am hoping your setting will work for me.
Thanks,
Jasen
Thanks,
Jasen
- Garnett-Bennett
14 Feb 2014 09:24 #20261
by Garnett-Bennett
Replied by Garnett-Bennett on topic Bixler 2 with Flaps + Devo 8s + RX802
Hi, I'm running Deviation-4.0.1, yes I did use a Y for the ailerons. Your challenge is the flaps with a 3 ch setup. Need another 2 to mix unless you buy a servo reverser. Cheers
- Jasen
14 Feb 2014 14:34 #20263
by Jasen
Thanks for the reply. I am going to use it as a 4 channel for now, and lock down the flaps.
- SadSack
14 Feb 2014 14:59 - 14 Feb 2014 15:00 #20266
by SadSack
Replied by SadSack on topic Bixler 2 with Flaps + Devo 8s + RX802
You can change the way the servo moves with extra hardware. You re-wire the pot in the servo.
Last edit: 14 Feb 2014 15:00 by SadSack.
Time to create page: 0.090 seconds
Model Configs
- Bixler 2 with Flaps + Devo 8s + RX802
