DSM2 Elevon Model Needed
11 Feb 2014 04:25 #20115 by Jefte
DSM2 Elevon Model Needed was created by Jefte
Coming from er9x I'm just not grasping this mixing UI. Can someone provide an elevon model for dsm2?
For the life of me I can't figure out how to remap channel order (AETR to TAER) on my 7e. Thanks.
11 Feb 2014 04:32 #20116 by vlad_vy
Replied by vlad_vy on topic DSM2 Elevon Model Needed
You can manually change sources for first 4 channel mixers.
Model menu -> Mixer -> (Simple or Expo&DR or Complex) -> Src = ???
12 Feb 2014 04:10 - 12 Feb 2014 04:15 #20160 by Jefte
Replied by Jefte on topic DSM2 Elevon Model Needed
I'm not sure what you mean Vlad. I see no way to change the channel order unless I edit the ini file directly. I see:
3-THR SIMPLE
THR
Doing what you suggest only results in:
3-THR SIMPLE
ELE
So I edited the ini file directly and have elevons partially working. They both move up/down as an elevator, but only one aileron moves when banking left/right. What am I missing?
Last edit: 12 Feb 2014 04:15 by Jefte.
12 Feb 2014 06:25 #20164 by FDR
Replied by FDR on topic DSM2 Elevon Model Needed
Those labels depend on the protocol.
Since the default protocol is the DEVO, it has the throttle on the third channel, but if you change the protocol to say DSMX, the first channel will be labelled as throttle...
12 Feb 2014 15:20 #20196 by Jefte
Thanks for the clarification FDR. I also learned on rcg that there was a bug when it comes that prohibited the channels from switching to the protocol-specific order when going from DEVO to DSM. I'll update to a more recent nightly (I'm on 4.0.1).
I think I'm slowly coming to terms with how mixes are created in Deviation, but still have issues with the model file posted above.
Time to create page: 0.065 seconds
