Syma X1 model and icon
19 Feb 2014 05:06 #20565 by hexfet
Syma X1 model and icon was created by hexfet
Used a posting of a Hubsan X4 model as a starting point, and the icon is from a zip file someone posted here. Will add credits if I can find them again. Icon is for Devo7e/10.
Fmode0: very gentle
Fmode1: about the same as stock tx high rate
Fmode2: aggressive
Sticky throttle cut on Rudder DR1
Auto-flip enable on Trim_R- (Devo10, next to mix switch). Hold down, then cyclic in direction to flip. It's a momentary switch set up according to the directions in the manual.
27 May 2014 20:13 #23712 by wim62
Replied by wim62 on topic Syma X1 model and icon
you will also have the settings for syma x5C?
28 May 2014 00:35 #23717 by hexfet
Replied by hexfet on topic Syma X1 model and icon
wim62 wrote: you will also have the settings for syma x5C?
I don't have that model. The X5C transmitter looks exactly like an X1 transmitter - have you tried binding using this model?
12 Jul 2015 02:42 #35352 by mntbkr
Replied by mntbkr on topic Syma X1 model and icon
I see in your description that the icon is for the 7e/10 but would the model file work with a7e? Thank in advance arms and thank you for sharing.
01 Dec 2015 19:40 #40532 by wim62
How can I add a 2nd timer to the x1?
Wim gr
17 Dec 2015 07:38 #41003 by Multirotor Go
Replied by Multirotor Go on topic Syma X1 model and icon
How can I get the aggressive mod if I have devo 7e that only has two, two position switches ?
Time to create page: 0.104 seconds
