DJI F550 / DEVO10 / Naza-M Lite
07 Apr 2015 11:24 #30870 by derzoko
Replied by derzoko on topic DJI F550 / DEVO10 / Naza-M Lite
Hello friends,
I just update my DEVO 10 with Deviation FW and loaded this DJI F SERIES model. It works perfect!! THANK YOU VERY MUCH! Just one problem, maybe could you help me, the only thing that doesn't works in my system is when I power off my radio it doesn't enter in failsafe mode. The rest works perfect.
My system is F450 / NAZA LITE / DEVO 10 / RX703a. I used DEVO and RX in a Walkera QR X350 PRO until two weeks ago and when I powered off the radio it entered in FS mode.
Any help? Thank you all in advance.
18 May 2015 05:33 #32721 by Cyber
Replied by Cyber on topic DJI F550 / DEVO10 / Naza-M Lite
How would I setup channel 5 to use retractable landing gear and what could i do to turn on and off navigation lights ?
Thanks...!!!
18 May 2015 14:39 #32739 by Bullfrog
Replied by Bullfrog on topic DJI F550 / DEVO10 / Naza-M Lite
Hello
Attached my latest file for Devo10, fitted with 2x switch channel + 2x linear AUX channel (currently one used for remote gain control), see info file for more details.
Meanwhile I changed to Devo12 and connot give that much support on Devo10.
If someone is interested in the Devo12 file please post.
19 May 2015 02:29 #32761 by Cyber
Thats great think you so muck!!!!!
02 Jul 2015 21:25 #35009 by Kirejevs
Replied by Kirejevs on topic DJI F550 / DEVO10 / Naza-M Lite
can be used your file with Devo f12e +RX802 + Naza M v2 ?
20 Jul 2015 12:37 - 20 Jul 2015 12:47 #35670 by PITCH13
Replied by PITCH13 on topic DJI F550 / DEVO10 / Naza-M Lite
Thank you for these files, very nice work and very very usefull!!, i modified V7 file to have flight modes on 3way MIX SWITCH , IOC control on FMOD SWITCH, i kept Failsafe on RUDD D/R SWITCH and dualrate on AIL D/R SWITCH, i'm using light switch on AUX 5 rotactor.
Here is the file for this configuration if it can help someone.
DEVO 10, RX1002, NAZA V2
electronic switch link:
Turnigy control relay switch, only use red wires
www.hobbyking.com/hobbyking/store/uh_vie....asp?idProduct=62804
File Attachment:
File Name: DjiF450V7bis.ini
File Size:4 KB
Last edit: 20 Jul 2015 12:47 by PITCH13.
22 Oct 2015 15:15 - 22 Oct 2015 15:16 #39131 by PITCH13
My last configuration, with Fail safe on elev switch, gear on gear switch (failsafe the gear comes down), gimbal tilt on AUX 4 rotactor, Leds on AUX 5 rotactor ,others unchanged :)
Last edit: 22 Oct 2015 15:16 by PITCH13.
06 Jan 2016 20:48 #41448 by Penny
Replied by Penny on topic DJI F550 / DEVO10 / Naza-M Lite
Hi, would you posibly have the settings for the dev10 fw7 I cant get the fw4 settings with the fw7 cheers
11 Jan 2016 05:58 #41614 by PITCH13
FW4, FW7 ? :unsure:
19 Sep 2017 15:01 #64513 by Doležaj
Replied by Doležaj on topic DJI F550 / DEVO10 / Naza-M Lite
Pleas what does it mean - switch fitted with 2x switch channel + 2x linear AUX channel ? Have you any picture?
Time to create page: 0.121 seconds
