Ladybird V2 with DEVO 7E
- Shlomo
15 Mar 2014 16:42 - 15 Mar 2014 16:43 #21568
by Shlomo
Ladybird V2 with DEVO 7E was created by Shlomo
Hi
I have Ladybird V2 which came with DEVO4 and worked fine.
Now , I got the DEVO 7E with deviation installed.
The LED in the ladybied turns on/off fast.
I am trying to bind the ladybird with the DEVO with no success.
In the Model Setup :
"*DEVO" (with *)
cannot ENTER the "Re-Init".
How can I bind it?
"*DEVO" (with *)
How can I bind it?
Last edit: 15 Mar 2014 16:43 by Shlomo.
15 Mar 2014 16:47 #21569
Replied by FDR on topic Ladybird V2 with DEVO 7E
Clear the fixed id field on the model setup page...
- Shlomo
15 Mar 2014 17:51 #21571
by Shlomo
Replied by Shlomo on topic Ladybird V2 with DEVO 7E
I already did that.
- linux-user
15 Mar 2014 21:32 - 15 Mar 2014 21:32 #21575
by linux-user
If Devo protocol is labeled "*DEVO (with *)", than something with your installation of deviation on the Devo7e is wrong.
Please install deviation again, according to the manual
deviationtx.com/user-manual/Documentatio...ion10UserManual.pdf/
Replied by linux-user on topic Ladybird V2 with DEVO 7E
Shlomo wrote: In the Model Setup :
"*DEVO" (with *)
Last edit: 15 Mar 2014 21:32 by linux-user.
- Hondawasaki
17 Mar 2014 17:59 #21621
by Hondawasaki
after the reinstall .... with the ladybird blinking fast ... and the fixed id cleared on the tx ... turn the tx off and back on again it should try to bind at start up ....if it does and the lady bird light goes solid... go back and assign a fixed id ... then you should be done .
Replied by Hondawasaki on topic Ladybird V2 with DEVO 7E
"*DEVO" (with *)
Time to create page: 0.068 seconds
Model Configs
- Ladybird V2 with DEVO 7E
