Mcpx config for Devo 7e
- stashen
18 Mar 2014 16:35 #21646
by stashen
Mcpx config for Devo 7e was created by stashen
Is there any one that can help me with a working config for the Blade Mcpx for use with the devo 7e?
- linux-user
- stashen
18 Mar 2014 21:50 #21656
by stashen
Replied by stashen on topic Mcpx config for Devo 7e
All Tom's configs seems to be compatible with all the devos except the devo 7e. This according to his notes in the post.
- linux-user
18 Mar 2014 22:26 #21657
by linux-user
I think it should work even with the 7e.
If it doesn't work, you could reassign the switches an shold be done.
Replied by linux-user on topic Mcpx config for Devo 7e
Have you tied it?stashen wrote: All Tom's configs seems to be compatible with all the devos except the devo 7e. This according to his notes in the post.
- stashen
19 Mar 2014 15:59 #21664
by stashen
Yes, but I was unable to bind the heli using that config, and tried both dsm2 and dsmx.
When I loaded up the profile for my ncpx that i downloaded from here, and was specifically for the devo 7e i was able to bind the heli just fine.
- linux-user
19 Mar 2014 21:01 #21672
by linux-user
The "bind process" has very little to do with the model config (except the protocol).
You did read Manual Chapter 9.5 to 9.6?
You may need a "bind plug".
Sorry I can't help any further, as I don't have any DSM2/DSMX receivers.
- Tom Z
24 Mar 2014 00:01 #21774
by Tom Z
My models will bind and work with the Devo 7e.
My custom GUI in the model file is also made to use with the 7e.
The issue is that the 7e has less switches. So you will only have one stunt mode plus you will not have DR/EXPO 1 and 2.
See my post here for an example:
deviationtx.com/forum/model-configs/2686...tings?start=20#20940
Replied by Tom Z on topic Mcpx config for Devo 7e
Time to create page: 0.498 seconds
Model Configs
- Mcpx config for Devo 7e
