Walkera QR Scorpion Y6 w/Devo 7e
06 May 2014 21:02 #22952 by jlk69
Walkera QR Scorpion Y6 w/Devo 7e was created by jlk69
Does anybody have this copter? If so is anyone using a 7e? I am having problems getting it to bind with my 7e. Any advice?
08 May 2014 17:26 #23022 by Tom Z
Replied by Tom Z on topic Walkera QR Scorpion Y6 w/Devo 7e
Fixed ID
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver
with the Bind Plug then assign any Fixed ID that you want to use.
