E-Flite Blade SR
14 May 2014 09:58 - 14 May 2014 09:59 #23222 by gregfrip04
E-Flite Blade SR was created by gregfrip04
I have been searching through and through this forum and I could not find anything about this heli. It seems to me that it's a popular CP trainer.
Any idea what config I should use for it?
Thank you for your help.
Regards, Greg.
Last edit: 14 May 2014 09:59 by gregfrip04.
19 May 2014 16:19 #23357 by gregfrip04
Replied by gregfrip04 on topic E-Flite Blade SR
Hello Fixy,
Thanks for your reply.
Unfortunately, this is absolutely not what I am looking for!!!
The Blade 120 SR is a FP whereas the Blade SR is a CP, so there is no way the settings would fit!
I have tried any Blade settings, nothing works with the Blade SR. It's just like the CH are not configured the same way or the swash is different, which is not the case.
I must admit that I don't understand anything about it. I am just about to leave it!
Regards, Greg
19 May 2014 16:22 #23358 by gregfrip04
Actually, I am having the same trouble with my V120d03 : the swash and servos are organized exactly the same way as the V120D02 but the config will not work with it!!!!!!!
19 May 2014 19:04 #23364 by Fixy
Replied by Fixy on topic E-Flite Blade SR
Ah sorry about that, I don't have a CP I can't help you much. Just try a similar model like mcpx for blade and super CP for walkera and you should be close to have a working profile with a little work you can probably figure it out.
Good luck.
20 May 2014 13:09 #23395 by gregfrip04
I finally resolved my trouble with the V120D03.
RX2613V receiver has a switch to reverse pitch servo which was set the wrong way.
Unfortunately, I could not find any such switch on the Blade SR.
Regards, Greg
10 Aug 2014 18:47 #25126 by el_rules13
Replied by el_rules13 on topic E-Flite Blade SR
This is the setting I have for my SR. You'll have to adjust pitch, throttle curve, and gyro.
Time to create page: 0.128 seconds
