file for glider with flap
13 Jun 2014 18:06 #24069 by bastien
file for glider with flap was created by bastien
I search a file .ini for glider and RX802(devo 8S) with flap(braking), aileron, elevator etc…
thank
19 Jun 2014 20:07 #24159 by bastien
Replied by bastien on topic file for glider with flap
For the glider with aile and flap and ++ RX802 mode 1
fmod0 : Aile + - 15 mm and flap + - 5 mm
fmod1 : aile + - 10 mm and flap + 3 mm for thermal
fmod2 : aile + - 10 mm and flap - 2 mm for speed
Mix 1 : flap + 15
Mix 2 : aile - 10, Flaps + 30 and depth + 5 for slow down and stopping)
11 Aug 2014 06:33 #25136 by Franck
Replied by Franck on topic file for glider with flap
Could you indicate how you plugged the servo on the receiver, do with a drawing, thank you
16 Oct 2014 05:53 #26093 by blackmoon
Replied by blackmoon on topic file for glider with flap
Bastien if you are still around, your model file doesn't correspond to the description.
It's an almost vanilla model file for a plane, no flight mods at all. Could you correct this, please :D
Thank you.
Time to create page: 0.056 seconds
