BavarianDeamon 3SX Devo 12 Rigid Mode
21 Aug 2014 13:48 #25316 by eraf
Hi there,
Here is my programming Devo 12 flashed with deviation-devo12-v4.0.1-92e1705
(If deviation from nightly-devo12-v4.0.1-fe45d83 work, I've only tested on the simulator)
Channel: MODE second
For the Gaui X5 FBL with Bavarian Demon 3SX and range DSMX satellites and
Savox servos
Only Rigitmode:
The following features emerge:
timer function
Channel 1-THR; Channel 2-AIL, ELE-3 channel; Channel 4-RUD; Channel 5 GEAR roundabout,
Channel 6 THR (Pitch), Channel 7 head centrifugal
Engine stop switch on Hold
Throttle curve and pitch curve switch on ALE / DR 0, 1, 2
Heckkreiseltrimmung on the left upper trim switch (TRIM_L)
Kopfkreiseltrimmung on the right upper trim switch (TRIM_R)
The stick trimmers are all disabled.
important:
Please fill in all settings and functions before the flight with the demon bavaria X-series software testing.
I am not liable for any damages
(Do not forget to back up your models before) Download text file and rename the txt Dateiendung.von after ini and copy to the model directory of the Devo 12
Have fun
BD3SX_Rigid
Sorry im Translate with Google
Time to create page: 0.068 seconds
