BavarianDeamon 3SX Devo 12 Horizontal and Recovery
21 Aug 2014 13:55 - 21 Aug 2014 13:56 #25317 by eraf
Hi there,
Here is my programming Devo 12 flashed with deviation-devo12-v4.0.1-92e1705
(If deviation from nightly-devo12-v4.0.1-fe45d83 work, I've only tested on the simulator)
Channel: MODE second
For the Gaui X5 FBL with Bavarian Demon 3SX and range DSMX satellites and
Savox servos
Rigitmode switched to channel 7 on Horizontal Mode and Recovery Mode
The following features emerge:
timer function
Channel 1-THR; Channel 2-AIL, ELE-3 channel; Channel 4-RUD; Channel 5 GEAR roundabout,
Channel 6 THR (Pitch), Channel 7 head centrifugal
Engine stop switch on Hold
Throttle curve and pitch curve switch on ALE / DR 0, 1, 2
All trimmers are all disabled.
Switches: MIX = 0 Rigid-function, MIX 1 = Horizontal Mode 80%,
MIX 1 = Horizontal Mode 90%
Rescue function on trainer switch
important:
Please fill in all settings and functions before the flight with the demon bavaria X-series software testing.
I am not liable for any damages
(Do not forget to back up your models before) Download text file and rename the txt Dateiendung.von after ini and copy to the model directory of the Devo 12
Have fun
BD3SX_Recovery Mode
Sorry im translate with google
Last edit: 21 Aug 2014 13:56 by eraf.
03 Sep 2014 07:14 #25478 by eraf
A small change:
The tail gyro channel is set to the upper left trimmer and can be connected to the transmitter set.
06 Jan 2016 10:21 #41430 by Sute
Stupid question. How can I download the txt-file in the firs post? It only opens a new page when tapping the link?
06 Jan 2016 12:11 #41432 by TomPeer
right-button mouse click.
save as...
06 Jan 2016 12:57 - 06 Jan 2016 12:57 #41434 by Sute
TomPeer wrote: right-button mouse click.
save as...
Any ideas how to get this installed to Devo 12s? I have devo upgrade tool and I´m able to connect to transmitter and install deviation firmware 4.01 to transmitter.
Last edit: 06 Jan 2016 12:57 by Sute.
Time to create page: 0.067 seconds
