RCL EOX Devo 10 Lemon Rx binds fine will not learn
02 Nov 2014 06:48 #26256 by sclui56
Recently used the Devo 10 with the OneLink, when the Lemon Rx arrived, had that installed, flashed Devo 10 with Deviation 4.01, loaded ini from MassiveRC. The Devo 10 binded fine to Lemon DSMX Rx with SAT, including FailSafe being enabled (solid red & green LED).
However, when I go into the EOX's learning process, I could only finish channel 1 (THR), when I activate RUD left to right, nothing happened. And if I aborted the learning after successful binding, my right stick at lower left would arm/disarm the motors, instead of the left stick as I am in Mode 2.
Am I missing a step?
