Blade 350QX Config/Template and Icon
10 Nov 2014 22:17 - 11 Nov 2014 01:30 #26341 by override
Blade 350QX Config/Template and Icon was created by override
Hello everyone,
Just recently picked up a Devo12s and uploaded Deviation firmware, so far my only RC is a Blade 350 QX Quad. I made this config/layout to utilize the blade basically as it is originally supposed to be configured.
The only thing different is I added 70% limits on the Aileron and Elevators both using Aile & Elev D/R switch position 1 for helping learn Agility mode and added motor kill onto a switch (you can still use trim)
Gear 1 is used for Return to home.
Trainer switch is used for resetting timer and stopwatch.
Hold 1 is used for motor kill.
Fmod is used for Mode selection (0-safe, 1- AP, 2-stability).
Trim R+/R- gives you options for Agility mode when in safe or stability mode.
Also included is a Model Icon I made of the Quad (I figured out how to get it transparent, uploaded the updated file)
I didn't see a separate file for the template but as far as I know the model file has all of it together. If anyone likes the setup, as soon as I get a gimbal I will be adding that to the config and can upload the updated file.
Thanks,
override
This was made on my Devo12s with 4.01 Firmware
File Attachment:
File Name: blade350qx.ini
File Size:4 KB
Last edit: 11 Nov 2014 01:30 by override.
10 Nov 2014 22:48 - 11 Nov 2014 01:34 #26344 by override
Replied by override on topic Blade 350QX Config/Template and Icon
Not sure why the BMP icon isn't showing correctly, if you right click and save it still will download correctly :)
Anyways here is what the layout looks like....
File Attachment:
Update: Here is what the transparent Blade Icon looks like, I also changed my background as I just figured out how to do it.
File Attachment:
Last edit: 11 Nov 2014 01:34 by override.
16 Nov 2014 17:19 #26427 by joecool
Replied by joecool on topic Blade 350QX Config/Template and Icon
Hey Override,
Looks cool, and works well. If by any chance you did get your gimbal (hopefully GB200), could you kindly let us know how you can control tilt with a DEVO, or eventually upload your config, that would be awesome.
Many thanks !
Joe Cool
16 Nov 2014 19:14 - 16 Nov 2014 19:14 #26429 by override
@joecool - My plan is to get a GB200 although I've looked at some Stella's too. All this is fairly new to me, been learning mainly by experimentation. if I can figure it out though i will for sure update the post.
Thanks,
override
Last edit: 16 Nov 2014 19:14 by override.
08 Dec 2014 14:56 - 08 Dec 2014 20:00 #26852 by override
I've been playing with working on getting a switch set to arm the motors, thanks to mattygermany, but no luck yet.
I also started messing with trying to get Stagility mode and believe I may have gotten it down. I'm going to go out and test it today but if it works...Would anyone be interested in my updating the ini file?
*Update*
I just finished testing this and it does in fact work as it should, I think I'm going to play around with the sensitivity a little more but otherwise I liked it.
Last edit: 08 Dec 2014 20:00 by override.
11 Dec 2014 08:07 #26889 by override
Umm yeah it's in the original post :)
