Alienwii/lemon rx config wanted (Devo 7e)
- mxer125
02 Feb 2015 20:07 #28367
by mxer125
Alienwii/lemon rx config wanted (Devo 7e) was created by mxer125
Is there such a file/ini ???....
I'm building a micro quad with Alienwii/lemon rx
I'm using the Devo 7e deviation 4.01 nightly...
Any advice would be greatly appreciated, many thanks in advance...
- ohhorob
03 Feb 2015 07:59 #28377
by ohhorob
Replied by ohhorob on topic Alienwii/lemon rx config wanted (Devo 7e)
I don't use any model file, just start a new one.
Pick DSM2 protocol.
Reverse AIL & RUD.
Add bind plug on AlienWii board, power up.
Hit "Bind" in Deviation model config, wait a couple of seconds for solid Rx light
Power down alienwii, remove bind plug
That's it..
Pick DSM2 protocol.
Reverse AIL & RUD.
That's it..
- mxer125
03 Feb 2015 21:23 #28388
by mxer125
Replied by mxer125 on topic Alienwii/lemon rx config wanted (Devo 7e)
Great Thank you ohhorob, 1st post a helping post too I am honoured, Thank you!!....
I'll give your advice a go when my lemon rx turns up, cheers
- MikeNola
08 Feb 2015 16:24 #28457
by MikeNola
Find attached the model file I have developed to fly picnic quads 120 frame with alienWii/lemonRx with Devo 10. Still a work in progress, haven't got the display icons for switches and such sorted out, but it will get you flying nicely.
Arm Motors:
Gear 1 = motors disarmed
Gear 0 = motors Armed
Gimbal Rates (rudder, aileron, elevator):
Rudd D/R 1 = 60%
Rudd D/R 0 = 100%
Flight Mode:
Mix 2 = Acro mode (gyro only...not self leveling)
Mix 1= Angle mode
Mix 0 = Horizon Mode
Mike
Replied by MikeNola on topic Alienwii/lemon rx config wanted (Devo 7e)
mxer125 wrote: Is there such a file/ini ???....
Arm Motors:
Rudd D/R 1 = 60%
Rudd D/R 0 = 100%
Flight Mode:
Mix 1= Angle mode
Mike
Time to create page: 0.028 seconds
Model Configs
- Alienwii/lemon rx config wanted (Devo 7e)
