Syma X11 config
02 May 2015 00:38 #31909 by cfl246tho
Syma X11 config was created by cfl246tho
As some of us are now successfully controlling our X11 quads with Deviation modded Devo controllers using the SymaX protocol, I went looking for an official "model config" thread here. Sorry if one ALREADY exists, in which case this should go there. But I couldn't find one, so I'm starting one.
Before I get into details, I just want to mention I flew my X11 yesterday with my Devo7E for the first time, and I have to say WOW :woohoo: It's like flying a new much better quad. Incredible. It's breathed new life into my X11 flying, which I have almost given up on... because yaw and pitch and roll are so weak on the stock controller.
I have a config. file working for the X11 (actually I have two), thanks to what Durete posted in "Devo 7e models" about five weeks ago. But following the rules here (which make good sense), I thought I'd start a place that focuses on the X11 variants ONLY.
Likewise, since the X12 quads work on the SymaX protocol too, we should create a separate thread for that particular model (even though the config files will probably be nearly 100% interchangeable).
If you're wondering, some icons for the X11 are posted over in the icons for Devo 7E/10 thread (B&W LoRes icons).
Right now I'm wondering if/how the config. file could be changed to produce better Yaw/Rudder.
I've posted my slight variation on Durete's file. Make sure you specify in the third line (or so) an icon you have in your "modelico" folder. The config. file version I'm uploading as "model1.ini" refers to an icon I created. Durete I think is using another one (a good one too). Neither are stock/default icons.
I'm gonna check again, but I think yesterday I got better yaw rate using another config, created on the Devo7, that uses "template=simple" for the channels (I'm uploading that one as "model3.ini") If that's true, the difference probably lies ways the curves are defined in the two (or three) different config. files.
Cheers
Quads: Syma X5, X11, X12; LishiToys L6052; NiHui U207, CG023; H7/SpaceTrek M9912; BayangToys X7; UDI U839/939; WLtoys V676; Cheerson CX205
02 May 2015 00:39 #31910 by cfl246tho
Replied by cfl246tho on topic Syma X11 config
Until yesterday I never dreamed my X11 could fly pitched so far forward. Incredible.
02 May 2015 13:39 - 02 May 2015 13:45 #31947 by cfl246tho
Seven channels (eight, but one is unused).
Useful related info from a recent draft of the Devo10/7E manual...
9.15 Protocol: SymaX
This protocol is used on Syma models: X5C-1, X11, X11C, X12, new X4, and new X6. A variant supporting the original X5C and the X2 is included as a protocol option (the Syma X3, old X4, and old X6 are supported with the SymaX4 option in the YD717 protocol). See the Supported Modules spreadsheet for a complete list.
NOTE: This protocol requires the addition of a ‘NRF24L01+’ hardware module to function. Note the "plus" version of the nRF device is required to support the 250kbits/s data rate. See the following document for more information: www.deviationtx.com/repository/Documenta...uleInstallation.pdf/
The SymaX protocol supports 7 channels and only supports auto-binding.
  • The first four channels represent Aileron, Elevator, Throttle, and Rudder.
  • The fifth channel is unused.
  • The sixth channel enables the auto-flip function when greater than zero.
  • The seventh channel takes a picture when the channel moves from negative to positive.
  • The eighth channel starts/stops video recording on each positive transition.
Last edit: 02 May 2015 13:45 by cfl246tho.
02 May 2015 20:14 - 03 May 2015 01:47 #31982 by mbk17
Replied by mbk17 on topic Syma X11 config
That yaw is incredible. However, on both my X5C-1 and X11 they both go leftwards and also turn slightly clockwise. Trimming does not seem to fix this as well.
Edit: I believe I fixed this with a stick calibration, sorry I am brand new to this stuff.
Last edit: 03 May 2015 01:47 by mbk17.
03 May 2015 23:25 - 04 May 2015 00:00 #32029 by cfl246tho
MBK17,
I was going to redirect you to an X5 config thread, then I could not find one.
I really can't help much with the X5. The one I "have" I actually gave to my nephew... out of state. I have read up on the X5, but I have not tried to use my Devo7E with it. So zero direct Deviation TX experience with it. I could only make general comments about the SymaX protocol.
Plus, such discussion would better take place in a separate X5 config. thread anyway. So I think I'll got start one. Yes, the config. file for all the Syma X5, X11, and X12 should be very similar, but invariably there will be comments made specific to one model or another. Again, comments are best made in threads for that specific model's config. file.
As far as technical assistance with an X5, there are various threads on topics for that quad scattered around. Try a search on "Syma X5" or similar. Best regards.
Last edit: 04 May 2015 00:00 by cfl246tho.
04 May 2015 00:03 #32030 by mbk17
Thanks for the reply. Just curious, is there a way to configure the FMOD switch to change between fast and slow modes? Because I find the current config too fast when taking video but excellent for fast/stunt flying. I think someone else answered this question in another thread but I would also like to make the EXT or ENT buttons to be used for flipping as opposed to using the HOLD switch. I've read the tutorial supplied for ini files but it is still confusing how to accomplish this.
28 May 2015 22:45 #33149 by ogrope1
Replied by ogrope1 on topic Syma X11 config
Can't thank you guys enough this thing is now my absolute best indoor fpv quad!
14 Jun 2015 04:09 #34044 by Michael_Hahnel
Replied by Michael_Hahnel on topic Syma X11 config
Hi, Can I get a copy of this manual ?
I don't seemed to have a Syma X protocol ?
thanks
21 Jun 2015 22:57 #34479 by Richard96816
Replied by Richard96816 on topic Syma X11 config
Just got my first Devo 7e working with Deviation. Very cool. It works with the JJR1000. But I can't figure out how to get the Syma X11 to auto-bind.
How do you do it? My Cheerson CX-10 doesn't want to bind either. I guess I only know how to do a manual bind.
22 Jun 2015 07:17 #34495 by Richard96816
Got the X11 working. Nice. Suspect I've got the wrong version of the CX-10.
04 Oct 2015 15:57 #38418 by MasterRC_sTudenT
Replied by MasterRC_sTudenT on topic Syma X11 config
How did you get it to auto-bind?
13 Nov 2015 06:34 #40000 by Unihiron
Replied by Unihiron on topic Syma X11 config
I have a strange issue with the Syma protocol. I just recently installed the nrf24l01 module for my Devo 7e and I followed the hacksmods tutorial here:
www.hacksmods.com/2013/05/nrf24l01-devo7e-pinout/
I was able to install and configure the firmware with no problem. However my X11 has bizarre erratic response. My commands are delayed and sometimes it outright doesn't respond in mid flight often flying right into a wall or ceiling because it lost input. But I can bind and fly the new JJ1000 and CG023 and those are two different protocols. I have absolutely no problems flying them. I maintained a constant hover with no lag or delay or drop out for 3 batteries worth of testing on BOTH quads. (3 flights a piece, 6 minute flights). I flashed one of the more recent nightly builds (i think 10/25/15). I've checked my soldering/connections and I have fresh batteries. I do not understand why the Syma X11 has bad response and two other protocols work fine. Any advise will be helpful. The nrf24l01 I'm using is not the banggood one. I got one that has an internal antenna on the circuit board.
13 Nov 2015 15:56 #40013 by hexfet
Replied by hexfet on topic Syma X11 config
Seems like your module is fine. How new is the X11? Syma is fond of tweaking their protocols. The behavior you describe could be explained by a protocol difference such as using a different method for choosing RF channels. The only way I can think to confirm would be to get SPI captures from your stock tx.
The SymaX protocol doesn't depend on receiving anything from the quad so a radio problem does not seem likely.
13 Nov 2015 21:20 #40022 by Unihiron
Well, I have more problems rising up now. For example. My cg023 and JJ1000 do not fly far at all..so I've done something wrong.
13 Nov 2015 21:55 #40023 by Richard96816
The Syma X11 is the first quad I flew with my Devo 7e when I got it. The quad was okay to start with, but the 7e made it an exceptional flier. I recently ordered another X11 since my first one has a lot of miles on it. Haven't received it yet. Hope the protocol change isn't too messy.
I do wonder why they bother making changes to quads that are already selling well. No new features were announced as far as I can tell.
Perhaps they don't like being reverse-engineered. :-/
13 Nov 2015 22:00 #40024 by Richard96816
Unihiron wrote: Well, I have more problems rising up now. For example. My cg023 and JJ1000 do not fly far at all..so I've done something wrong.
You did say your module has the on-board antenna. They are decidedly much shorter range. The modules with the external antenna usually have additional amplification. Check out the banggood units ...
19 Nov 2015 00:49 #40197 by Unihiron
I didn't check the forum but then I knew I had problems I immediately knew what I did wrong.
Whoever reads this,
PLEASE ONLY GET THE BANGGOOD NRF24L01 MODEL!!
Wait a month and don't be impatient. I bought two from America that had faster shipping. One module stated it had a 1,000 meter range. Well, it drops data packets at any range and sent my quadcopters straight into walls and ceilings (I flew inside just in case I had a run-away). Then I got one with a built in antenna, and that little guy went 30 feet and then I lost signal. Ultimately, it was a waste of money to get similar modules. I just got my Banggood NRF24L01 module and everything works fine. Range is good. Syma X11 does not drop out. I hope this helps someone who is new to this. Not all modules work. If it looks any different than the one that is from Banggood, it will not work. If you are not sure, get it from Banggood. It will work. Don't take shortcuts, just wait. Save money. Go fly a kite.
24 Jan 2016 21:38 #42177 by Dreamer338
Replied by Dreamer338 on topic Syma X11 config
Firstly, I have to state that I only started learning about quad stuff and Deviation about a month ago. And big up to all you guys to feed my tinkering addiction, what a way to soend the snowy nights soldering :-)
However, when I switch to high rates on my Devo 10, the rudder channel outputs zero. With low rates, the rudder works well. Any ideas on ehat could cause this?
24 Jan 2016 23:20 - 24 Jan 2016 23:22 #42184 by RedSleds
Replied by RedSleds on topic Syma X11 config
Most likely a problem with your model config/ini file.
Try this one with your DEVO 10 >>>
File Attachment:
File Name: model2.ini
File Size:8 KB
Config notes:
My version, cobbled together from a JJRC JJ-1000 config from peanut man.
Three rate modes:
FMOD 0
FMOD 1
FMOD 2
Flip mode:
RUD D/R 0 = Flip OFF
RUD D/R 1 = Flip ON when in high rates with FMOD 2
Last edit: 24 Jan 2016 23:22 by RedSleds.
25 Jan 2016 10:26 #42198 by Richard96816
Thanks for posting the model file.
I put your 'Config notes' stuff into the file as comments before I saved a copy.
Would be nice if folks would get in the habit of posting them that way.
Time to create page: 2.202 seconds
