Syma X12 config.
- cfl246tho
06 May 2015 21:36 - 06 May 2015 21:37 #32190
by cfl246tho
Quads: Syma X5, X11, X12; LishiToys L6052; NiHui U207, CG023; H7/SpaceTrek M9912; BayangToys X7; UDI U839/939; WLtoys V676; Cheerson CX205
Syma X12 config. was created by cfl246tho
Starting a thread for this model, which uses the SymaX protocol, which is available (as of now) in the nightly builds (but not the 4.01 release).
My config attempts to push the Yaw rate on this slow Yaw model. The X12 yaw doesn't benefit as much as the X11 model's yaw rate does to DeviationTX custom controls.
I also shape my curves, for gentle responsiveness near base position (zero throttle, center stick for the other controls), then more responsiveness (larger increments of change) as you move the stick further from center. Kind of like using acceleration settings with a mouse. It helps me finely maneuver at slow speeds or slow motions (AIL, ELE, RUD, even THR).
Flip is channel 6, not channel 5, which works when HOLD1 is active, an you move the ELE or AIL far enough. I discovered I can keep flying normally with HOLD1 on as long as I don't push those too far. If I do, it flips
FMODE0 and 1 have slightly different rates, but even the gentler FMODE0 is more responsive than the Syma controller. You could turn that down. I leave it this way and just keep stick near center if I don't want too much motion change.
My own icon (non standard) is specified in the config. file. You'll need to pick one you have on your Devo. For convenience I'm attaching my icon here. I previously posted it where it best can be found, over in the Devo 7E/10 icons thread
Last edit: 06 May 2015 21:37 by cfl246tho.
- cfl246tho
16 May 2015 20:28 #32660
by cfl246tho
Replied by cfl246tho on topic Syma X12 config.
There seems to be a newer X12S version
that might not work with current Deviation TX. Just know that if you have one and are trying this config. for it, it might not work.
- IKKI
26 Jun 2015 11:49 #34681
by IKKI
Replied by IKKI on topic Syma X12 config.
Thanks for the explanation, but I have not yet figured out how to disable the automatic launch if I move the stick too directional. Thank you. The maximum range as it is?
- vroomvroom
17 Dec 2015 22:04 #41008
by vroomvroom
Replied by vroomvroom on topic Syma X12 config.
Just updating this thread with a Syma X12S config. Working with 4.0.1-583c468 on the Devo 7E
- NutraBind
28 Feb 2016 22:56 #43863
by NutraBind
Replied by NutraBind on topic Syma X12 config.
Have you actually tried this on a X12S?
As I recall, I have tried this on the same nightly with no luck (but I may have mixed up things). For sure this file does not work on with my X12S using a bit newer nightly (667678f) on my Devo 7e
On the other hand, the stock transmitter binds with both my X5C-1 v6 and the X12S, so there may be a solution already.
Time to create page: 0.897 seconds
Model Configs
- Syma X12 config.
