Xinxun X39 config
- 187
03 Sep 2015 04:24 - 03 Sep 2015 04:25 #37394
by 187
Xinxun X39 config was created by 187
I slapped a x39 xinxun board on a 120mm frame with 8.5mm motors.
It is flying great after a bit of playing however...
it will randomly do a high speed flip if I do a high speed run and try to slow down to a hover... only some times.
also the yaw is slow but no adjustment seems to effect it.
has anyone had any luck with this yd /xinxun protocol and setting this up well?
edit - I need to figure out where the rates and flip is more specifically.
Last edit: 03 Sep 2015 04:25 by 187.
- 24inwork
04 Sep 2015 10:29 #37436
by 24inwork
Replied by 24inwork on topic Xinxun X39 config
Hello dude i have seted up module from my XinXun Tx to devo 10 today and be able to bind my quad but the control is a bit crazy.
I am not sure how it is called correctly Aileron? When I pull right stick full forward it takes a huge angel and go down how to decrease it ?
Also i am not sure but it looks like i do not have full throttle is there any way to check this?
- 187
05 Sep 2015 04:43 #37458
by 187
Replied by 187 on topic Xinxun X39 config
Try this one see if it works.
- 187
05 Sep 2015 05:11 #37459
by 187
If anyone here is familiar with this model could you add the rates and the flip to the above config as it only contains the first four channels so far.
thank you
thank you
- 24inwork
08 Sep 2015 16:37 - 08 Sep 2015 16:43 #37573
by 24inwork
Guys plz help with this one
Lights turn on/off not working but flip is turned on and not turning off with this code wich i wanted to trigger on GEAR switch
Hovering flight mode Fmode0,
Sport mode Fmode1
Experimental Fmode2
[channel5]
template=simple
max=100
min=0
[mixer]
switch=RUD DR0
dest=Ch5
curvetype=min/max
points=0
[channel6]
max=100
min=0
template=simple
[mixer]
src=GEAR0
dest=Ch6
curvetype=min/max
points=0Hovering flight mode Fmode0,
Sport mode Fmode1
Experimental Fmode2
Last edit: 08 Sep 2015 16:43 by 24inwork.
- 24inwork
08 Sep 2015 21:44 #37575
by 24inwork
The last flying build
- 24inwork
15 Sep 2015 08:23 - 15 Sep 2015 08:24 #37775
by 24inwork
The last stable config for XinXun 39 or any other models wich you want to fly, just replace the protocols,
config for Devo 10 but it will work for most Devos with devention software.
My XinXun39 frame is dead a little bit, so i am waiting for spare parts that's why config a little bit ugly, i will make it more optimized in code and style when i will fix my xinxun.
3 Flight Modes support on FMODE (Right Switch)
0 - Begginers mode, very soft, responsive and nice to fly for beginners.
1 - Advanced mode more aggressive and responsive.
2 - Advanced mode testing.
AUTO FLIP TURN ON/OFF ON GEAR SWITCH
NOTES: XINXUN39 has only 5 channels to control. There is no way to turn on/off lights ;((
Last edit: 15 Sep 2015 08:24 by 24inwork.
- 187
16 Sep 2015 03:18 #37797
by 187
nice going to test this now
- 24inwork
16 Sep 2015 16:20 #37806
by 24inwork
How it is going ?
- 187
16 Sep 2015 21:43 #37808
by 187
Its good, auto flip on and off on channel 5 HOLD0 and 1 is working
I had to disable the 1st mode and just use the 2nd and 3rd as I have a Devo7e
In both advanced flight mode 1 and 2 it is responding very nicely, I didn't bother with flight mode 0
- 187
17 Sep 2015 03:10 #37813
by 187
I forgot to mention, when I used your config, ELE and AIL are swapped, needed to change this and it was ok.
- Gazono
19 Nov 2015 19:35 #40222
by Gazono
Replied by Gazono on topic Xinxun X39 config
For lights control try to move both sticks in the bottom-right corner for 2-3 sec. I have X30 board with Devo7e. It works.
Time to create page: 0.066 seconds
Model Configs
- Xinxun X39 config
