Blade Inductrix for Devo 7E
- ethernode
19 Sep 2015 09:20 - 19 Sep 2015 09:26 #37880
by ethernode
Blade Inductrix for Devo 7E was created by ethernode
Here is my config for the Blade Inductrix on Devo 7E, which is (heavily) based on Daryoon's Nano QX config. HOLD switches acro mode and FMOD changes rate between high and low rate (60%). The perfect quad for learning acro !
Also, there is only a 5 min countdown (reset using L-) and a permanent timer. Quick page is channel monitor.
PS: took me a while to discover that filenames (and icon names) had to be less than 8 characters long.
Last edit: 19 Sep 2015 09:26 by ethernode.
- mjsnosk8
18 Feb 2016 18:29 - 18 Feb 2016 18:31 #43245
by mjsnosk8
Replied by mjsnosk8 on topic Blade Inductrix for Devo 7E
Thanks for the config and icon. Here is my inductrix ini for Devo7e. hold0=throttle cut, fmode=rates, yaw trim=acro/safe toggle, throttle trim=toggle very low rates for learning acro.
Last edit: 18 Feb 2016 18:31 by mjsnosk8. Reason: identify my tx.
- duke4you
24 Mar 2016 19:21 #45111
by duke4you
Replied by duke4you on topic Blade Inductrix for Devo 7E
i tried the config from ethernode on my modded Devo10 but the Quad doesn't.
There is no throttle on the stick.
When i look in the channels i can see the value of throttle is moving.
I tried the config from mjsnosk8 the can fly, throttle is OK.
So what is wrong? PLZ help me i'am a Devo newbie.
What is the hold0=throttle cut, fmode=rates, yaw trim=acro/safe toggle, throttle trim=toggle very low rates
THX
cu
THX
cu
- Thomas.Heiss
24 Mar 2016 21:08 #45118
by Thomas.Heiss
Replied by Thomas.Heiss on topic Blade Inductrix for Devo 7E
Try switching between Hold0 (TH=throttle cut) and Hold1.
You need to see -100-0-+100 values changing in Transmitter menu / channel monitor. On TH 0 throttle will be fixed to -100 (off).
To actually be able to start the motors you probably need to do some magic stick movement (see the manual for the correct start sequence). On the 200QX you had to e.g move both sticks on the inner bottom sides at the same time.
- modemman
06 Apr 2016 12:59 - 08 Apr 2016 14:55 #45915
by modemman
Replied by modemman on topic Blade Inductrix for Devo 7E
Thanks so much for the files (and the icon - so hard to make something that looks like anything with so few black pixels...)
Everything works for me on the Devo 7E, but I have a question about trimming:
Since this is all based on mixers, how do you trim?
My quad tends to drift to one side. Also, I know this is off topic, but is there some calibration mode for the Inductrix other than plugging the battery and quickly placing on a flat surface? For example, on my Hubsan X4 you can place the quad flat and then perform a calibration routine (you wiggle the sticks in a certain order) that reorients the gyros to the new 'flat'. Thanks.
EDIT: I figured out my calibration/trim issue: one of my motors is going bad (or maybe ESC issues?) so when I apply heavy throttle the quad drifts heavily to the side with the bad motor. I assumed it has to do with the mixers inside the Devo and the way the trims are programmed, but it is a motor issue. I will replace the motor as soon as I can get one and continue testing.
Last edit: 08 Apr 2016 14:55 by modemman. Reason: Figured it out...
- Sharplosc
16 Jun 2016 13:49 #50694
by Sharplosc
Replied by Sharplosc on topic Blade Inductrix for Devo 7E
I have the same problem with ethernode
My inductrix spin and drift a lot
I must trim a lot for stable (RUD +40 !!!! For exemple), what's wrong with this model file ?
With radio rtf no problem
- steveroby
26 Jun 2016 03:44 - 26 Jun 2016 03:47 #51078
by steveroby
Replied by steveroby on topic Blade Inductrix for Devo 7E
When using someone elses .ini , dont assume anything. Ive tried shared ini's that had heaps of trim in them as default. Also , shared ini's may have had other tweeks that you dont know about.
Use it as a starting point only. The ini's above may be just fine, but who knows
Also, have you run the calibration on the Transmitter?
The inductrix should just work with a basic 4ch airplane/heli/quad setup. Try that first then look at configuring the switches.
Given a very basic DX5 works on the inductrix, so any eflite/hh/parkzone micro ini should get you in the air.
Last edit: 26 Jun 2016 03:47 by steveroby.
- bigicedog
03 Jul 2016 05:46 #51265
by bigicedog
Replied by bigicedog on topic Blade Inductrix for Devo 7E
noob question. do i need a special module or no. and if yes which one?
- D_an_W
03 Jul 2016 05:58 #51266
by D_an_W
Replied by D_an_W on topic Blade Inductrix for Devo 7E
As far as I know all Blade use DSMX which don't need anything extra (Other than Deviation of course) but I don't have one to test.
- bigicedog
03 Jul 2016 06:32 #51267
by bigicedog
ok. cause i cant get mine to bind...
- slavin23
13 Sep 2016 16:18 #53839
by slavin23
Replied by slavin23 on topic Blade Inductrix for Devo 7E
Anyone manage to set the inductrix to do flip?
- Josegonzalez1985
18 Sep 2016 02:25 #53986
by Josegonzalez1985
Replied by Josegonzalez1985 on topic Blade Inductrix for Devo 7E
I have a devo 10, how do I set the acro/stability mode to a switch
- vent357
01 Oct 2016 23:03 #54486
by vent357
Replied by vent357 on topic Blade Inductrix for Devo 7E
Thanks great job!
- raketemensch
14 Oct 2016 18:22 - 14 Oct 2016 18:23 #54923
by raketemensch
This is an old post, but it comes up in Google, so I figured I'd respond for others who end up here. I loaded mjsnosk8's ini file, bound to the drone, and the little bugger just corkscrewed to the left. I cranked the trim all the way to the right, and still couldn't compensate -- it was unflyable.
I was trying to figure out how to calibrate the drone when I realized that I hadn't calibrated the TX. It's dead-simple, but if you'd like a video there's one here:
After this I am in awe of how well this thing flies. It makes my X4s feel like flying a bus.
Replied by raketemensch on topic Blade Inductrix for Devo 7E
Sharplosc wrote: I have the same problem with ethernode
Last edit: 14 Oct 2016 18:23 by raketemensch.
- ksquad
08 Nov 2016 14:58 #55804
by ksquad
Replied by ksquad on topic Blade Inductrix for Devo 7E
Thank you for the calibration video! Fixed my problems!
- Jetracer
30 Nov 2016 00:27 #56369
by Jetracer
Replied by Jetracer on topic Blade Inductrix for Devo 7E
Is there a way to swap throttle? When i power up my left stick does nothing while my right stick is my throttle
- jimgazer
20 Jan 2017 17:10 #58246
by jimgazer
Replied by jimgazer on topic Blade Inductrix for Devo 7E
Thanks, really helped, mine was full trim left but still spinning right, now it's great.
- WildDoktor
14 Feb 2017 21:51 #59143
by WildDoktor
Replied by WildDoktor on topic Blade Inductrix for Devo 7E
Obviously this thread is oooooold, but I had to log in to say: Thank you so much ethernode!!! My Blade arrived today; so I ran home at lunch, unpacked it, and used your config on my 7e to bind and fly. I was up in the air within 20 seconds! Low rates and high rates are nice and smooth (I'll tweak them a bit to my liking), and acro is impossible because I'm a beginner.
I've never flown FPV before, but after about 30 seconds of flying LOS in low rates I was so confident that I went ahead and put on my ev800s and took off. I flew the rest of the battery FPV, all the way to the back of my house and back to me. Woo Hoo!
So anyway, thanks...I'm going to have a HOOT with this thing and this config!
- Texacate
15 Apr 2017 23:50 - 20 Apr 2017 02:27 #61498
by Texacate
Replied by Texacate on topic Blade Inductrix for Devo 7E
I had the same problem when I first started. (an un-calibrated transmitter) This necessary step should be included in the Getting Started Guide.
I'm trying to figure out how to improve the User Manuals. (who to contact, where to post enhancement ideas) Filing a bug report does not the seem proper thing to do,since (so far) I haven't found any blatant errors, just lots of opportunities to improve them.
Last edit: 20 Apr 2017 02:27 by Texacate. Reason: typos
16 Apr 2017 07:50 #61506
Replied by FDR on topic Blade Inductrix for Devo 7E
You can change them using Github's web interface.
You need to register, I think...
Time to create page: 0.225 seconds
Model Configs
- Blade Inductrix for Devo 7E
