DEVO RX RANGE ????????????
  • paiste2002
  • paiste2002's Avatar Topic Author
  • DEVO 12S
24 Oct 2015 05:04 - 24 Oct 2015 05:21 #39162 by paiste2002
DEVO RX RANGE ???????????? was created by paiste2002
Hi All,,, I own a DEVO 12s . What is the range for the RX 1202 , RX 802 , RX 801 , RX 702 , & the Mini 601 ,, Please ... No one seems to know and to make it worse no SPECS on the RX's .. Cheers
Last edit: 24 Oct 2015 05:21 by paiste2002.
28 Oct 2015 10:11 - 28 Oct 2015 11:57 #39291 by Thomas.Heiss
Replied by Thomas.Heiss on topic DEVO RX RANGE ????????????
I just use Spektrum receivers.
With Spektrum AR6210 on 1mw output power I got about ~60m ground range test with NO holds, and <40 FrameLosses.
This means I had not lost steering control when doing the range tests.
Spektrum says reduced power tests should be fine up to ~30m (maybe also 35m).
Pilots fly with genuine Spektrum receivers after those tests in full range hundrets of meters high / away (also big gliders).
You might want to test and compare.
What are you plans, where do you like to put the receivers into? What plane / heli / quad are you going to fly?
Thomas
Last edit: 28 Oct 2015 11:57 by Thomas.Heiss.
28 Oct 2015 10:33 - 28 Oct 2015 10:42 #39293 by vlad_vy
Replied by vlad_vy on topic DEVO RX RANGE ????????????
I think all Devo Rx are "Full Range". You can test it with 300uW output power, you have to get about 30m range. Or about 30 times bigger for full output power (100mW).
I think real power output for Deviated Tx is wrong:
www.deviationtx.com/forum/3-feedback-que...er-150mw-100mw#32518
So, for 1/1000 output power range test you need to use 300uW output power.
Last edit: 28 Oct 2015 10:42 by vlad_vy.
28 Oct 2015 12:24 - 28 Oct 2015 12:25 #39295 by aMax
Replied by aMax on topic DEVO RX RANGE ????????????
vlad_vy wrote: I think all Devo Rx are "Full Range". You can test it with 300uW output power, you have to get about 30m range. Or about 30 times bigger for full output power (100mW).
What about this measurement?
Setting at 100mW = 103mW output.
ht......tps://www.youtube.com/watch?v=cDcr3iFtqvo
at...24:35
Last edit: 28 Oct 2015 12:25 by aMax.
28 Oct 2015 13:33 - 28 Oct 2015 13:33 #39299 by vlad_vy
I don't know. I have measured output power Devo 8s with Deviation and with original firmware (100mW), the same results. Deviation 150mW = Devo 100mW.
Last edit: 28 Oct 2015 13:33 by vlad_vy.
28 Oct 2015 17:39 #39310 by mwm
Replied by mwm on topic DEVO RX RANGE ????????????
vlad_vy wrote: I don't know. I have measured output power Devo 8s with Deviation and with original firmware (100mW), the same results. Deviation 150mW = Devo 100mW.
PB says that 150mW gives you very little increase in range and a large increase in power consumption, and recommends using the 100mW setting for "full range" work.
Can you measure the deviation output at 100mW?
28 Oct 2015 17:47 #39313 by vlad_vy
You can find all answers at link above.
Time to create page: 0.108 seconds
