DEVO 10 AND DEVO-RX-710
06 Dec 2015 19:06 #40633 by ccrisostomo
DEVO 10 AND DEVO-RX-710 was created by ccrisostomo
Collegues
can you help us indicating if are compatibles DEVO 10 with DEVO-RX-710?
thanks
Carlos
13 Dec 2015 19:15 #40886 by SirDomsen
Replied by SirDomsen on topic DEVO 10 AND DEVO-RX-710
Yes it is
14 Dec 2015 15:27 #40918 by ccrisostomo
Replied by ccrisostomo on topic DEVO 10 AND DEVO-RX-710
Dear Domsen, please indicate how we can bind DEVO 10 with RX-710. When we do the binding process, elements showed paired, but receiver dont activate any servo.
thanks
14 Dec 2015 18:51 #40927 by SirDomsen
Do you use deviation? As so, did you assign the channels to the servo connections in your devo, assuming you made a new model.ini?
if you want a preconfigures ini, try - just for testing - a walkera model.ini from the model files section. For examle the miniCP or the ladybird - depending on the numer of channels you want to use. the mini cp has 7 channels like the rx710...
14 Dec 2015 19:51 #40930 by ccrisostomo
I'am not using Deviation yet. So if we use this SW, we can configure all channels. We are using this RX for Walkera runner 250. May be you can recomend any model.ini? or you ocnsider the miniCP will work fine?
Can I find here a tutorial of Deviation? Can you explain me all capabilities of Deviation?
thanks
Carlos
14 Dec 2015 20:55 #40934 by SirDomsen
1)
You CAN configure all channel
2)
For the runner, you can find here an existing threat in the forum, just use the search
3)
MiniCP won't work as it is a Heli
4)
In the download section there is a manual. It shows how to use and how to configure everything
5)
Look at the model,database. That's what you can control using deviation when solder a few new transceiver modules on,your Devo. At least all walkeras and all spektrums can be controlled with stock deviation without modding the tx.
Something else: While you're using stock Devo10, it HAS to work with the receiver - perhaps the rx is defective or somethinge else went wrong while binding the rx to the Devo. Did you clear the fixed ID?
Time to create page: 0.192 seconds
