Daming Dm003 (spy mini drone) to Slow
07 Apr 2016 00:08 - 07 Apr 2016 00:22 #45985 by kenstogie
Daming Dm003 (spy mini drone) to Slow was created by kenstogie
so i am setting up a .ini for my Daming DM003 on a deviated 7e and it works aok...i did have to reverse the aileron channel but i was able to figure it out even though i have had it for only about 2 weeks.
HOWEVER......it goes slow slow slow like it is on low rates
what am i missing?
many thanks!! and i will be happy to share my .ini when i fix it
Last edit: 07 Apr 2016 00:22 by kenstogie.
23 Oct 2016 21:46 #55319 by Treeman
Replied by Treeman on topic Daming Dm003 (spy mini drone) to Slow
Did you ever figure this out? Did you need the additional radios or did the stock Devo one work?
17 Dec 2016 18:41 #56919 by bazsound
Replied by bazsound on topic Daming Dm003 (spy mini drone) to Slow
they usually have a channel to set low and high rates. what protocol does it use? if you look up the protocol in the devation manual. It should list what each channel is usually for.
usually you just set -100 for low and +100 for high.
there are many mini quads/drones that use that same tx but there are several different protocols used depending on which one its cloned friom.
27 Sep 2018 22:14 #71071 by Leonquad
Replied by Leonquad on topic Daming Dm003 (spy mini drone) to Slow
Recently bought a DM003 as well and it flies really nice and quiet! Would love to bind it to my Devo 7e with 4in1 and Deviation 5.0.0. Anyone here who managed to get this to work? Tried CX10 protocol with DM007, Green, etc. But nothing seems to work.
16 Oct 2018 19:11 #71417 by Leonquad
Problem solved. Latest version of the DM003 seems to use the DM002 protocol. (Used most recent nightly firmware for Devo 7e)
Time to create page: 0.079 seconds
