FT Arrow
07 Apr 2016 16:50 - 07 Apr 2016 16:58 #46042 by czindrick
FT Arrow was created by czindrick
I copied this www.deviationtx.com/forum/3-feedback-que...-delta-wing-question
Which works great for my servos..right stick functions as needed...however I have no throttle. The ESC just keeps beeping..yesterday with a fresh model it worked just fine. Not sure what is going on.
Can someone help me out?!?
Also I am wondering how I would set max throws as there is a certain length the servo needs to travel.
Thanks!!
Last edit: 07 Apr 2016 16:58 by czindrick.
07 Apr 2016 17:23 #46043 by czindrick
Replied by czindrick on topic FT Arrow
To add to this confusion the ESC stopped beeping after I,put the throttle at 100% but still no movement from the motor..this is pretty much my final step before I can fly :(
07 Apr 2016 18:48 - 07 Apr 2016 21:22 #46054 by Arnold
Replied by Arnold on topic FT Arrow
Have you calibrated sticks?
Have you calibrated the ESC?
Last edit: 07 Apr 2016 21:22 by Arnold.
07 Apr 2016 20:32 - 07 Apr 2016 20:34 #46065 by stevecox
Replied by stevecox on topic FT Arrow
After calibrating the sticks, if that didn't work, then with the propellor OFF the motor, reverse the throttle channel output and try again.
Adelaide
Last edit: 07 Apr 2016 20:34 by stevecox.
07 Apr 2016 21:54 #46073 by czindrick
I actually got it working. I unhooked everything. Checked my safe levels which was at 0. My setup goes to -100% so, I adjusted my settings to match that and it armed and worked. I just need to verify that the other settings are correct. It may be worth it to post my .ini file?
Thanks for the help!
24 Apr 2016 13:24 - 24 Apr 2016 13:25 #47092 by czindrick
Anyone know why this could be happening? No input on left input and then jittery movement on the end of the video?
Obviously I need to adjust my throws but I am so close now..just cannot pinpoint this one....
YouTube Video
Last edit: 24 Apr 2016 13:25 by czindrick.
25 Apr 2016 08:00 - 25 Apr 2016 08:01 #47145 by Alexandro
Replied by Alexandro on topic FT Arrow
im flying a Wing Wing z-84 with this ini
1. is elevator
2. is Aileron
3. is Motor
i hope it helps to get your Plane into the Air :)
-> rename it to the right Name modelX X= (Number)
-> if your Ruders are working wrong direction , try to change 1 with 2
greetings Alex
File Attachment:
File Name: model4Wing...isel.ini
File Size:4 KB
Last edit: 25 Apr 2016 08:01 by Alexandro.
26 Apr 2016 04:23 #47210 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic FT Arrow
czindrick wrote: No input on left input and then jittery movement on the end of the video?
What's your setup with the servos and linkages there? What are you using as pushrods? Can you post a pic, I can't figure it out, and the servos seem to be moving weird.
27 Apr 2016 13:31 - 27 Apr 2016 22:04 #47301 by Cereal_Killer
Replied by Cereal_Killer on topic FT Arrow
Update: I got Chris going great! Stupid backwards-from-everyone-else emax servos threw a kink in it, I actually had to build a model with all his parts to test on but I got it.
He's confirmed the mixer I built him is working 100% with a video he sent me on Facebook last night.
Here is that model .ini
File Attachment:
File Name: Devoelevon...rvos.ini
File Size:4 KB
Last edit: 27 Apr 2016 22:04 by Cereal_Killer.
Time to create page: 0.041 seconds
