FT Arrow
- czindrick
07 Apr 2016 16:50 - 07 Apr 2016 16:58 #46042
by czindrick
FT Arrow was created by czindrick
I copied this
www.deviationtx.com/forum/3-feedback-que...-delta-wing-question
Which works great for my servos..right stick functions as needed...however I have no throttle. The ESC just keeps beeping..yesterday with a fresh model it worked just fine. Not sure what is going on.
Can someone help me out?!?
Also I am wondering how I would set max throws as there is a certain length the servo needs to travel.
Thanks!!
Thanks!!
Last edit: 07 Apr 2016 16:58 by czindrick.
- czindrick
- Arnold
- stevecox
- Keep swinging
- czindrick
07 Apr 2016 21:54 #46073
by czindrick
Replied by czindrick on topic FT Arrow
I actually got it working. I unhooked everything. Checked my safe levels which was at 0. My setup goes to -100% so, I adjusted my settings to match that and it armed and worked. I just need to verify that the other settings are correct. It may be worth it to post my .ini file?
Thanks for the help!
- czindrick
24 Apr 2016 13:24 - 24 Apr 2016 13:25 #47092
by czindrick
Anyone know why this could be happening? No input on left input and then jittery movement on the end of the video?
Obviously I need to adjust my throws but I am so close now..just cannot pinpoint this one....
YouTube Video
YouTube Video
Last edit: 24 Apr 2016 13:25 by czindrick.
- Alexandro
25 Apr 2016 08:00 - 25 Apr 2016 08:01 #47145
by Alexandro
Replied by Alexandro on topic FT Arrow
im flying a Wing Wing z-84 with this ini
1. is elevator
2. is Aileron
3. is Motor
i hope it helps to get your Plane into the Air
-> rename it to the right Name modelX X= (Number)
-> if your Ruders are working wrong direction , try to change 1 with 2
greetings Alex
1. is elevator
2. is Aileron
3. is Motor
greetings Alex
Last edit: 25 Apr 2016 08:01 by Alexandro.
- RoGuE_StreaK
26 Apr 2016 04:23 #47210
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic FT Arrow
What's your setup with the servos and linkages there? What are you using as pushrods? Can you post a pic, I can't figure it out, and the servos seem to be moving weird.czindrick wrote: No input on left input and then jittery movement on the end of the video?
- Cereal_Killer
27 Apr 2016 13:31 - 27 Apr 2016 22:04 #47301
by Cereal_Killer
Replied by Cereal_Killer on topic FT Arrow
Update: I got Chris going great! Stupid backwards-from-everyone-else emax servos threw a kink in it, I actually had to build a model with all his parts to test on but I got it.
He's confirmed the mixer I built him is working 100% with a video he sent me on Facebook last night.
Here is that model .ini
Last edit: 27 Apr 2016 22:04 by Cereal_Killer.
Time to create page: 0.811 seconds
