LED's off after load / bind
24 Apr 2016 12:53 #47090 by Newman
LED's off after load / bind was created by Newman
I have this model file for a Hubsan X4 on a Devo 7E that I got from a friend. The HOLD switch arms / disarms and the FMOD switches the rates. The LED's turn off as soon as I load the model file and the quad binds. It never used to when I first started using it, so I must have accidentally changed some code or there is some other issue. Can anyone please help as I love flying this at night but now I am grounded Thanks
24 Apr 2016 15:20 #47098 by Deal57
Replied by Deal57 on topic LED's off after load / bind
In my Hubsan-protocol Proto-x channel 5 controls the LEDs. So if channel 5 is -100 they are off. Since there isn't a channel 5 in your ini file it is defaulting to off. Add channel 5 to a switch if you have one, or else just give it a fixed value of 100.
25 Apr 2016 00:36 - 25 Apr 2016 00:48 #47126 by Newman
Replied by Newman on topic LED's off after load / bind
Thanks Deal 57. I am a rank amateur with model files do you mind adding that channel to my posted file for me so I can start learning how to do this stuff for myself :)
EDIT - I just looked at another model file I had and added this which seems to work. Thanks a lot for your help :cheer:
[channel5]
template=simple
[mixer]
src=0
dest=Ch5
scalar=-100
curvetype=min/max
points=0
Last edit: 25 Apr 2016 00:48 by Newman. Reason: Additional info
25 Apr 2016 01:07 #47127 by Deal57
Nice! :)
Time to create page: 0.083 seconds
