Cheerson cx-10a cx-10w cx-10c
07 Jun 2016 19:51 #50126 by jjk836
Cheerson cx-10a cx-10w cx-10c was created by jjk836
Recently bought a fleet of a cx-10a, cx-10w and cx-10c. They all listen to the same procotol. Find the model ini attached for devo 10 with the following features:
CH1 AIL Dual Rate on AIL DR
CH2 ELE Dual Rate on ELE DR
CH3 THR
CH4 RUD Dual Rate on RUD DR
CH5 FMOD Flightmode -100, 0, 100 (powerlevel, headless mode)
CH6 TRIM_R+ flip (virt5, virt6, trim6) push button and move cyclic to direction
CH7 TRIM_L+ photo (virt7, trim7)
CH8 TRIM_L- video on/off (virt8, trim8)
TRIM_R- Gyro callibration (only if THR=0)
GEAR Emergency throttle hold
MIX throttle curve 0=1-1, 1=heavy model, 2=light model
Have fun.
My ini file repository bitbucket.org/jjk836/devo10
11 Jun 2016 04:35 #50379 by caughron01
Replied by caughron01 on topic Cheerson cx-10a cx-10w cx-10c
I have the Cheerson CX-10c I have loaded this into my Devo 10 but I cannot get the CX-10 to sync with my controller. With my little white controller it came with I have to push the throttle up then pull back and it syncs. Can you help me out? Thanks
11 Jun 2016 09:59 #50391 by jjk836
Replied by jjk836 on topic Cheerson cx-10a cx-10w cx-10c
Do you have the nRF chip installed? Is there a * in front of the cx-10 protocol?
You might want to try a different flavor of the protocol. See other options in this list
docs.google.com/spreadsheets/d/1nBHzT3VW...kHn1RIM84/edit#gid=0
11 Jun 2016 15:10 - 11 Jun 2016 15:10 #50400 by caughron01
I snapped a picture of my board on my cx-10c. Can you tell me from the pic if that is supported? I don't see nrf though.
Last edit: 11 Jun 2016 15:10 by caughron01.
11 Jun 2016 15:40 #50404 by jjk836
I don't know. My question was if you modded the tx with the additional nRF module.
11 Jun 2016 16:00 #50406 by caughron01
Oh no I've never done that, but I bought second hand and it had some stuff done to it but I'm not sure all that was done and I don't have a proper tool to open it up. Takes a special bit.
11 Jun 2016 16:38 - 11 Jun 2016 16:40 #50407 by HappyHarry
Replied by HappyHarry on topic Cheerson cx-10a cx-10w cx-10c
it uses a 2mm allen key to open, and you'd best open it and see what's in there, or ask who you purchased it from so you'll know what craft are compatable
Last edit: 11 Jun 2016 16:40 by HappyHarry.
11 Jun 2016 17:27 - 11 Jun 2016 17:28 #50408 by caughron01
Ok I got it open the I have attached a couple images of the chips I saw. Not sure what is what inside there honestly. Thanks for the help I really appreciate it as I'm trying to learn this.
Last edit: 11 Jun 2016 17:28 by caughron01.
11 Jun 2016 19:08 #50413 by HappyHarry
that's the main mcu and a voltage regulator, see the large rectangle that's a silver box, about 2" x 1 1/2" are their any extra wires soldered to that going to a seperate small pcb? if not your tx is totally stock
11 Jun 2016 20:58 #50428 by caughron01
The silver thing in the first pic thats below the big black square module?
11 Jun 2016 21:21 - 11 Jun 2016 21:22 #50432 by HappyHarry
no, that's a crystal in the picture of the mcu, here's a pic of the inside of a devo8, the thing with the blue V drawn on it is the stock rf module for the d10,
if you have extra modules added there will be wires soldered to the pins of that leading to a separate pcb('s) like so
Last edit: 11 Jun 2016 21:22 by HappyHarry.
11 Jun 2016 22:25 #50435 by caughron01
Ok so now I understand I do not have any mods should I add the nrf and the other one in the pic would that open up to a lot more stuff I can control?
Where do I get them and are there instructions here to install those?
I have a pretty fair hand when it comes to soldering just need to k ow my input locations. Thanks so much Harry you've opened my eyes on what this controller can really do.
11 Jun 2016 22:54 - 11 Jun 2016 22:58 #50436 by HappyHarry
no probs bud, we're all here to help and be helped after all :) yeah adding extra rf modules opens up the use of models that use those specific rf chips for their protocol. the stock devo rf board will do devention (obviously lol) and when you install deviation it will also work with spektrum dsm2/dsmx. so if you want to fly models and use rx's that aren't one of those you'll need to add modules.
having a read through the wiki would be a good starting point for modding information
www.deviationtx.com/wiki/
but also there is a new module that's recently been released that contains all of the commonly used rf chips in one module which isn't mentioned in the wiki yet, also there is a newer revision of it about to be released that will be practically plug and play (bar soldering 3 wires) for the devo10 that also fixes a few issues from the initial version. you can find the info on that board here >> www.deviationtx.com/forum/7-development/...-3in1-4in1-rf-module
Last edit: 11 Jun 2016 22:58 by HappyHarry.
12 Jun 2016 06:11 #50450 by SodaAnt
Replied by SodaAnt on topic Cheerson cx-10a cx-10w cx-10c
So I just got a 3-in-one module and deviation installed today, yay! However, I can't get my CX-10A go to anything other than a glacial pace. I've tried this config, made my own, but nothing I can do will make it do anything more than barely tilt. It is flyable, but nowhere near the speeds I can get using the stock controller. Changing the power mode doesn't seem to help, and flips don't seem to work either, but headless mode does. Any ideas what the heck might be going on? Flips I can easily live without, but I want to go fast!
12 Jun 2016 19:09 - 12 Jun 2016 21:36 #50483 by caughron01
Hey Harry I went in for a double take today and I found out that I do have that module needed for the cx-10. I have included a picture of my module.
Is there something I need to do to activate or switch to the NRF module?
Last edit: 12 Jun 2016 21:36 by caughron01.
13 Jun 2016 00:01 #50500 by HappyHarry
cool, is it soldered in to your d10? if so you'll just need to enable the module in hardware.ini and setup the model with the correct protocol. all the info you nees to do this is in the wiki I linked you above and in the manual >> www.deviationtx.com/user-manual/user-manual-7e-10 if it's not soldered in you'll need to do that first, again the info for that is in the wiki :)
13 Jun 2016 01:21 - 22 Jun 2016 23:49 #50515 by caughron01
Its fixed, turns out my board was bad.
Last edit: 22 Jun 2016 23:49 by caughron01.
04 Sep 2016 23:21 #53476 by Squirrel_D
Replied by Squirrel_D on topic Cheerson cx-10a cx-10w cx-10c
So I'm trying to get my cx-10 W to work with my 7e. The only module I put in is the nrf module and I know that's working because I control my Syma x5c-1 with it.
I've tried a couple of model files I've found but only one was for the 7e, either way, no joy. Can someone help me please? How should I proceed?
26 Sep 2016 20:32 #54304 by daich
Replied by daich on topic Cheerson cx-10a cx-10w cx-10c
SquirrelD did you get this sorted?
I have the Nrf module as well which works with me CX10 but I can't get it to work with my CX10c
Are there versions of the CX10c that do not use a NRF based protocol?
25 Feb 2017 22:58 - 26 Feb 2017 00:27 #59629 by CARONTE
Replied by CARONTE on topic Cheerson cx-10a cx-10w cx-10c
Salve ho un CX10W e col cellulare è scomodo controllarlo.
Ho acquistato un controller del CX10C ma non si connettono.
Il mio drone ha il PCB verde, anche il controller.
Sul PCB del controller c'è scritto questo:
KY - CX 10T - 01 - REV 01
FR/4=1MM
Ho controllato i chip sui PCB:
Controller: XN297 1546 (PCB separato dalla MB)
CX 10 W: XN297 LCU 1615b
Volevo chiedere a chiunque di voi possa aiutarmi a connettere il drone col controller, posso anche cambiare il FW se qualcuno mi invia i file giusti.
Grazie a voi ho potuto conoscere molte cose su questo drone e ho visto le connessioni per collegare il mio USB/TTL con chip Silabs 2102
Perdonate il traduttore :)
Hi I have a CX10W and her cell phone is inconvenient to control.
I purchased a CX10C controller, but do not connect.
My drone has a green PCB, even the controller.
I say this on the controller PCB:
FR / 4 = 1MM
I checked the chips on the PCB:
Controller: XN297 1546 (from separate PCB MB)
I wanted to ask anyone of you can help me to connect the controller with the drone, I can also change the FW if someone sends me the right files.
Thanks to you I got to know a lot about this drone and saw connections to connect my USB / TTL chips Silabs 2102
Forgive the translator
Last edit: 26 Feb 2017 00:27 by CARONTE.
Time to create page: 0.226 seconds
