WL v977 RTF Radio clone on 7E
- saerdnaa
15 Jun 2016 18:51 #50662
by saerdnaa
WL v977 RTF Radio clone on 7E was created by saerdnaa
I tried a lot of configs, but at the end I tried to create a model.ini that should mirror the RTF function.
Devo 7E without mods (except NRF radio module)
Hold toggle just hold
Fmod is idle up toggle (working only in 3d mode)
Right trims used to replicate 3d/6g toggle and dual rate toggle
Left trim vertical used to change pitch (working only o+)
Hover debug is not present (don't know how to implement)
I usually fly 3d, so 6g mode is no perfect...need to implement trims for 6g flight if needed
Have fun
Have fun
- yakky
11 Aug 2016 18:07 #52681
by yakky
Replied by yakky on topic WL v977 RTF Radio clone on 7E
Thanks for posting this config. I found a few others but they used three way switches. You did a great job with the toggles and even the 3g/6g icon. Excellent work!
- TF824
18 Sep 2016 10:52 #54005
by TF824
Replied by TF824 on topic WL v977 RTF Radio clone on 7E
Finally I found BEST config for V977!!!!! Very Happy with your V977 Data.
This is the one I was looking for, Best of Best, Pitch range adjustment / DR by Ele trim / 3D6G Change by Ail trim.
You are the MAN.
Thanks for GREAT JOB Mr. Saerdnaa
You are the MAN.
Time to create page: 0.039 seconds
Model Configs
- WL v977 RTF Radio clone on 7E
