Please Bayangtoys x16 model ini.for devo 10.
23 Jul 2016 02:30 #52037 by C0ckpitvue 777
Please Bayangtoys x16 model ini.for devo 10. was created by C0ckpitvue 777
Does anybody have a Bayangtoys model ini file they care to share for the devo 10.The model file I have for my 7e doesn't work for the 10 unless I'm missing something.All help will be greatly appreciated.This is the model file I'm using,it binds but the stick method doesn't arm it.
name=X9
mixermode=Advanced
type=multi
[radio]
protocol=Bayang
num_channels=11
fixed_id=123456
tx_power=150mW
[channel1]
template=simple
[mixer]
src=AIL
dest=Ch1
scalar=125
[channel2]
template=simple
[mixer]
src=ELE
dest=Ch2
scalar=125
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
scalar=125
offset=3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
scalar=125
[channel5]
template=expo_dr
[mixer]
src=HOLD0
dest=Ch5
scalar=125
curvetype=zero/max
points=0
[mixer]
src=HOLD0
dest=Ch5
switch=HOLD1
curvetype=zero/max
points=0
[channel6]
template=simple
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
value=100,0,0
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
23 Jul 2016 05:39 #52044 by mwm
Can you provide more details than "doesn't work"? It should bind and do basic flying with no issues. If that's not working, then a new model.ini file won't help.
23 Jul 2016 18:36 #52059 by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Please Bayangtoys x16 model ini.for devo 10.
It binds it just doesn't arm with the stick sequence with my devo 10.It works great with my 7e.Appreciate the fb,still trying to figure it out.
23 Jul 2016 21:14 #52065 by C0ckpitvue 777
I figured out the problem,it's fixed had to switch the rudder assignment.
22 Sep 2016 23:02 #54135 by dononeness
Replied by dononeness on topic Please Bayangtoys x16 model ini.for devo 10.
C0ckpitvue 777 wrote: I figured out the problem,it's fixed had to switch the rudder assignment.
Hi C0ckpitvue 777, could you please re-post the file or values that you fixed?
Thank You
23 Sep 2016 02:12 #54140 by C0ckpitvue 777
Sure,Fmod has the 3 rates,keep it in the middle for mid rate because high rate is too much for the motors.Rudder1 is throttle hold and ail 1 is headless.
name=Rolling Thunder(x16)
mixermode=Advanced
[radio]
protocol=Bayang
num_channels=11
fixed_id=123456
tx_power=150mW
[channel1]
template=complex
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
scalar=80
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE2
usetrim=0
curvetype=expo
points=25,25
[channel2]
template=complex
[mixer]
src=ELE
dest=Ch2
scalar=60
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
scalar=80
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE2
usetrim=0
curvetype=expo
points=25,25
[channel3]
safetysw=RUD DR1
safetyval=-110
template=simple
[mixer]
src=THR
dest=Ch3
curvetype=expo
points=0,0
[channel4]
template=complex
[mixer]
src=RUD
dest=Ch4
scalar=60
curvetype=expo
points=25,25
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
scalar=80
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
usetrim=0
curvetype=expo
points=25,25
[channel6]
template=simple
[mixer]
src=ELE DR1
dest=Ch6
curvetype=expo
points=0,0
[channel9]
template=simple
[mixer]
src=AIL DR1
dest=Ch9
curvetype=zero/max
points=0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
value=-10,0,0
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
value=100,0,0
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
Toggle=4,10,0,9,0,RUD DR
TxPower=102,7
23 Sep 2016 02:48 - 23 Sep 2016 03:45 #54144 by dononeness
C0ckpitvue 777 wrote: Sure,Fmod has the 3 rates,keep it in the middle for mid rate because high rate is too much for the motors.Rudder1 is throttle hold and ail 1 is headless.
mixermode=Advanced
[radio]
protocol=Bayang
num_channels=11
fixed_id=123456
tx_power=150mW
[channel1]
template=complex
[mixer]
src=AIL
dest=Ch1
scalar=60
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE1
scalar=80
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=AIL
dest=Ch1
switch=FMODE2
usetrim=0
curvetype=expo
points=25,25
[channel2]
template=complex
[mixer]
src=ELE
dest=Ch2
scalar=60
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE1
scalar=80
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=ELE
dest=Ch2
switch=FMODE2
usetrim=0
curvetype=expo
points=25,25
[channel3]
safetysw=RUD DR1
safetyval=-110
template=simple
[mixer]
src=THR
dest=Ch3
curvetype=expo
points=0,0
[channel4]
template=complex
[mixer]
src=RUD
dest=Ch4
scalar=60
curvetype=expo
points=25,25
[mixer]
src=RUD
dest=Ch4
switch=FMODE1
scalar=80
usetrim=0
curvetype=expo
points=25,25
[mixer]
src=RUD
dest=Ch4
switch=FMODE2
usetrim=0
curvetype=expo
points=25,25
[channel6]
template=simple
[mixer]
src=ELE DR1
dest=Ch6
curvetype=expo
points=0,0
[channel9]
template=simple
[mixer]
src=AIL DR1
dest=Ch9
curvetype=zero/max
points=0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
value=-10,0,0
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
value=100,0,0
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
TxPower=102,7
Thank you so much C0ckpitvue 777. Is it for Bayang Toys x16 for Cheerson Cx-20? I am looking for Bayang Toys X16.
Also, I just copy and paste it to notepad++ and save as "model.ini" file but it does not work. It does not bind to the X16.
Could you please attach the ini file (to have a correct format) instead? Thank You again.
Last edit: 23 Sep 2016 03:45 by dononeness.
23 Sep 2016 03:50 #54147 by C0ckpitvue 777
What devo do you have?This is for the devo 10,the other one I posted is for the devo 7e.Did you put both sticks to the lower outer corners to arm it?
Time to create page: 0.081 seconds
