RODEO 150 / DEVO8s
- jaeyang9
31 Jul 2016 07:46 - 01 Oct 2016 06:02 #52310
by jaeyang9
RODEO 150 / DEVO8s was created by jaeyang9
Created this config on Devo 8s.. icon for white Rodeo150 is also attached.
DON'T FORGET TO SAVE CHANGES IN CLEANFLIGHT
3 Flight Modes via 3 way FMOD switch
FMOD 0 - ANGLE (Slide bars to 1800-2000 under Modes in CleanFlight)
FMOD 1 - HORIZON (Slide bars to 1400-1600 under Modes in CleanFlight)
FMOD 2 - ACRO
Motor Arming/Disarming & Throttle Hold via RUD switch
RUD 0 - ARMED
RUD 1 - DISARMED & Safety Throttle Hold @ -110% in case you do not enable switch setting
*Requires enabling switch setting "arming via AUX channel" under Config in CleanFlight, and also add range ARM / AUX 2 & Slide bars to 1000-1200 under Modes in CleanFlight
ELEV & AIL DR 0 - 100%
ELEV & AIL DR 1 - 70%
Adjust to your liking.. enjoy!
FMOD 2 - ACRO
RUD 0 - ARMED
Last edit: 01 Oct 2016 06:02 by jaeyang9. Reason: correction
- Infamous2117
03 Aug 2016 03:13 #52410
by Infamous2117
Replied by Infamous2117 on topic RODEO 150 / DEVO8s
Will this work with my DEVO 10?
- Arnold
03 Aug 2016 04:11 - 03 Aug 2016 04:11 #52411
by Arnold
Replied by Arnold on topic RODEO 150 / DEVO8s
Your Devo 10 has all the same switches in the same locations as the Devo 8S, but also has the two rotary dials on top of the controller, which the 8S doesn't have. So, this .ini file should be fine for your Devo 10 & RODEO 150. Just be sure to satisfy the requirements for CleanFlight that jaeyang9 outlined in his post. And have fun with it!Infamous2117 wrote: Will this work with my DEVO 10?
Last edit: 03 Aug 2016 04:11 by Arnold.
- Infamous2117
03 Aug 2016 04:20 #52412
by Infamous2117
Awesome, i havent purchased it yet but will be very shortly.
Good to know i can buy the BNF version, Much appreciated.
Time to create page: 0.028 seconds
Model Configs
- RODEO 150 / DEVO8s
