Devo10 Hobbyking Minimoa
12 Aug 2016 16:27 #52705 by jchevli22
Devo10 Hobbyking Minimoa was created by jchevli22
Balanced for gliding motor off with one of the two weight the plane came in with and a 1800 3s battery
lemon dsmx rx with satellite
Max throttle for 15-30 sec then gliding 15-20 min flying time
rudder switch: throttle cut
elevator: dual rate
plane pitch up a lot with throttle: elevator- throttle down mix on gear switch
aileron organized as flapero: flap 1 and 2 on mix switch
Aileron brake on aileron switch
timer on reset on fmode witch
Time to create page: 0.193 seconds
