WLtoys Q333 INSPIRE1 CLONE DEVO7E BIND
- micro heli club
23 Jan 2017 03:29 - 23 Jan 2017 03:33 #58311
by micro heli club
WLtoys Q333 INSPIRE1 CLONE DEVO7E BIND was created by micro heli club
Last edit: 23 Jan 2017 03:33 by micro heli club.
- ajtank
31 Jan 2017 07:18 #58584
by ajtank
Replied by ajtank on topic WLtoys Q333 INSPIRE1 CLONE DEVO7E BIND
Oh interesting. What protocol did you use?
- jay
01 Feb 2017 13:03 #58611
by jay
Replied by jay on topic WLtoys Q333 INSPIRE1 CLONE DEVO7E BIND
Good job. I also try to bind it but it was not successful.
Would you share your ini file for Q333?
- micro heli club
01 Feb 2017 14:41 #58615
by micro heli club
Replied by micro heli club on topic WLtoys Q333 INSPIRE1 CLONE DEVO7E BIND
The protocol is Q303.
・HOLD SW⇒Skid MOVE
・FMOD SW⇒DR
・LEFTtrim(left)⇒Headless mode
・LEFTtrim(light)⇒Home return
About operation is not guaranteed.
・HOLD SW⇒Skid MOVE
・FMOD SW⇒DR
- ajtank
02 Feb 2017 02:22 - 02 Feb 2017 13:12 #58637
by ajtank
Oh it is unexpected that Q333 shares the same protocol as Q303, nice !
Q333 transforms sequentially upon toggling of Ch6 whilst it triggers flipping on Q303.
However Q333 can also flip according to ad's posted on the web stores. If you can provide SPI capture I suppose Goebish can add a sub-format for Q333.
edit: I downloaded the manual and did not see a flip button on the stock transmitter, only the transform button.
Last edit: 02 Feb 2017 13:12 by ajtank.
- micro heli club
02 Feb 2017 02:31 - 14 Mar 2017 11:23 #58640
by micro heli club
Hello.
Please release the model data of WIFI and 5.8 Camera.
Last edit: 14 Mar 2017 11:23 by micro heli club.
- ajtank
02 Feb 2017 03:34 #58641
by ajtank
Have you read the thread for Q303:
www.deviationtx.com/forum/protocol-development/6441-wltoys-q303
Have you tried ch7 and ch8 for the photo and video?
- ajtank
02 Feb 2017 03:47 #58642
by ajtank
If you are using a 3-in-1 or 4-in-1 module, then the binding problem is likely due to the crystal accuracy. Change the capacitors as shown here
jay wrote: Good job. I also try to bind it but it was not successful.
- jay
02 Feb 2017 14:57 #58658
by jay
Thank you for your advice. I got 3 in 1 module with metal cap.
www.banggood.com/CC2500-NRF24L01-A7105-M...04.html?rmmds=search
It seems that it is almost impossible for me to remove the cap and replace capicitors.
Do you use same ini configuration with micro heli club shared?
If not, please share yours. Let me try one more time.
- ajtank
02 Feb 2017 15:15 - 03 Feb 2017 02:20 #58659
by ajtank
Using different configuration files will not improve the binding. I do not have the Q333 but only Q303. I assisted developer Goebish to create the Q303 protocol. micro heli club discovered that Q303 protocol could also apply to Q333. Anyway I attach my file for Q303. Note that it is for use on Devo 10 only.
ch5: altitude hold for Q303 (gear switch)
ch6: flip for Q303 but transform for Q333 (ele dr switch)
ch7: photo for Q303 (left upper trim+ button)
ch8: video for Q303 (left upper trim- button)
ch9: headless for Q303 (right upper trim+ button)
ch10: return to home for Q303 (right upper trim- button)
ch11: gimbal control for Q303 (throttle trim+/- buttons)
You may also connect an additional nRF24L01+ module on your Devo transmitter. Just disable the nRF chip on the 3-in-1 and enable the external one.
Last edit: 03 Feb 2017 02:20 by ajtank.
Time to create page: 0.694 seconds
Model Configs
- WLtoys Q333 INSPIRE1 CLONE DEVO7E BIND
