Need KX K110 model.ini for Devo 7e
- Gerhard_H
24 Feb 2017 11:14 #59557
by Gerhard_H
Need KX K110 model.ini for Devo 7e was created by Gerhard_H
Hi!
I need the model.ini for a KX K110 heli and a Devo7e radio - 4in1 module active and switch mod (2 switches).
I do have a working ini file but don't know how to switch between 3D and 6G mode (at the moment I'm stuck on 3D mode without knowing how to leave).
Alas the helo lacks on documantary like channel list etc.
Furthermore : Gyrosettings out of interest today ?
Any help will be highly appreciated !
TIA
Gerhard
TIA
Gerhard
- Amelanchier
24 Feb 2017 14:06 #59560
by Amelanchier
Replied by Amelanchier on topic Need KX K110 model.ini for Devo 7e
Take a look at this thread:
www.deviationtx.com/forum/builds/5569-xk...devo-10?limitstart=0
You should find all the configs you need in there.
- Gerhard_H
24 Feb 2017 14:52 #59563
by Gerhard_H
Replied by Gerhard_H on topic Need KX K110 model.ini for Devo 7e
Thx, but I do know this thread and I'd tried out the attached ini. But it doesn't work at all. The heli flies like beeing drunken. I also own a Futaba T14SG (as reference), when I bind the heli there it flies nicely.
I just wanted to know which channel switches the mode and which values are needed
- Amelanchier
24 Feb 2017 19:22 #59578
by Amelanchier
I'm currently flying mine like this:
Channel 1 = AIL
Channel 2 = ELE
Channel 3 = THR
Channel 4 = RUD
Channel 5 = Mode (6G = -100 3D = 100)
Channel 6 = Pitch
I had to calibrate my gyro and accelerometer out of the box to get it flying reasonably. The procedure can be found here:
www.rcgroups.com/forums/showthread.php?2...7-XK-K110-micro-heli
Channel 1 = AIL
Channel 2 = ELE
Channel 3 = THR
Channel 4 = RUD
Channel 6 = Pitch
- Gerhard_H
24 Feb 2017 19:58 #59579
by Gerhard_H
THX a lot !
Time to create page: 0.055 seconds
Model Configs
- Need KX K110 model.ini for Devo 7e
