E010 option missing under MJXq
03 Apr 2017 11:57 #61115 by rybarnes
E010 option missing under MJXq was created by rybarnes
I just wrapped up modding my 7E with the 3 in 1 module. I followed the pin out from
The google map can't be displayed, ask your administrator for more details
, but made a few changes. I gave up on the pin 13 onto the ARM chip, wanting to avoid damage so I moved the 2041 pin to were the 7105 chip was supposed to be connected. I changed the pins on the hardware.ini file to match. (enable-nrf24101 = A13) Now I'm booting up and getting no missing module errors. I'm able to get to the MJXq protocol and the sub selection, but E010 is not listed.
Did I do something wrong? Can the 2041 select pin not be put where I put it? Something wrong about the hardware.ini file? Simply missing the E010 model for some reason?
03 Apr 2017 13:46 #61118 by rybarnes
Replied by rybarnes on topic E010 option missing under MJXq
I should specify that I am using the v5.0.0 main release. Not a nightly build. I'll try a nightly build later this evening and see if it isn't just a version issue.
03 Apr 2017 13:57 #61119 by Nowayray
Replied by Nowayray on topic E010 option missing under MJXq
i think your right on your second post,
i am runnung a newish nightly build and the option is there..
Good luck
03 Apr 2017 14:51 #61120 by micro heli club
Replied by micro heli club on topic E010 option missing under MJXq
Hello!!
enable-nrf24101 = A13⇒A15
try!!
03 Apr 2017 17:04 #61127 by rybarnes
micro heli club wrote: Hello!!
try!!
I gave up on the pin 13, not wanting to damage it. So I put the 2401 select pin to where the 7105 went (pin 9 in the labeled images). I'm imaging there isn't any difference between these pins. They are presumably simple digital writes to define what chip is selected. Am I incorrect?
03 Apr 2017 20:59 #61143 by rybarnes
Problem solved. The most recent nightly build did the trick. I was able to bind straight away and I am business.
30 Apr 2017 01:19 #61855 by Stavridis
Replied by Stavridis on topic E010 option missing under MJXq
Please tell me how you fix this. I have the same problem. E010 format from MJXq is missing
10 May 2017 23:51 #62223 by Texacate
Replied by Texacate on topic E010 option missing under MJXq
E010 support was not available at the time of the standard 5.0.0 release (May 2016)
You'll need to install a newer build, such as this one, from May of 2017:
www.deviationtx.com/forum/builds/6407-de...cols?start=200#62154
Time to create page: 0.177 seconds
