Blade F-27 FPV UMX with SAFE
31 Aug 2017 18:45 - 31 Aug 2017 21:21 #64080 by Ariete
Blade F-27 FPV UMX with SAFE was created by Ariete
I successfully configured a model for this new little plane.
Here is the model from my Devo 8S for the Blade F-27 UMX with SAFE.
File Attachment:
File Name: model32_20...8-31.ini
File Size:24 KB
You have self levelling on FMOD0 and FMOD1 and only AS3X on FMOD2.
I don't know why but you have to "arm" the plane switching to GEAR1 a couple of seconds on then turning back to GEAR0.
Sticky throttle cut is on RUD D/R1.
The timer linked to throttle can be reset with MIX2.
It has telemetry ON but I am trying to figure out if there is anything that the receiver is sending.
Last edit: 31 Aug 2017 21:21 by Ariete.
